Modelling question
15 posts • Page 1 of 1
kepler
Modelling question
Post by kepler » Wed Feb 21, 2007 2:58 am
Hello, how can I model a text "recessed" in a mesh like in this image? Using booleans would be very complicate to do!
Sorry for the stupid question (not for me, though).
drBouvierLeduc
Post by drBouvierLeduc » Wed Feb 21, 2007 3:23 am
Isn't that just a bump-map ?
Otherwise I don't see a simple way to achieve this, except using boleans.
kepler
Post by kepler » Wed Feb 21, 2007 3:36 am
drBouvierLeduc wrote:Isn't that just a bump-map ?
Yes, maybe bump-map is the only alternative. I should study more about these techniques...
SmartDen
Post by SmartDen » Wed Feb 21, 2007 3:56 am
with new 2.43 version you can displace it as well
manitwo
Post by manitwo » Wed Feb 21, 2007 4:02 am
:D indeed i used bumpmapping.
kepler
Post by kepler » Wed Feb 21, 2007 7:00 am
Thank you very much for the replies!
I need some tips about making (text) bump-maps. I've tried writing in white the word "indigo" in a square, black, image and then using it as a bump-map with a "b" factor 0.001 on a gold cube. Here's the result:
As you can see the text is not realistic, you can't compare it with that of manitwo's image :?
I've tried with "b" equal to 0.01, 0.0001 but in the first case it seems to "sharp", in the second there's no difference with the "b = 0.001" image. :shock:
My conclusion is that probably is my bump-map image that is wrong; what should I do?
@ manitwo: can you show me the bump-map you've used to make the can picture?
kepler
Post by kepler » Wed Feb 21, 2007 7:05 am
SmartDen wrote:with new 2.43 version you can displace it as well
Thank you, I'm studying that way too!
drBouvierLeduc
Post by drBouvierLeduc » Wed Feb 21, 2007 7:06 am
two advices : use a rather high resolution image (>1000 x 1000), and blur it a little, avoid pure black and white
manitwo
Post by manitwo » Wed Feb 21, 2007 7:09 am
kepler
Post by kepler » Thu Feb 22, 2007 7:28 pm
Thank you very much again! I have another question: is it possible to export displacement maps into Indigo? It seems not... I have read this guide to learn the basics of displacement (the site is unavaiable at the moment that I'm writing this post) and I can achieve very nice results but I'm not able to use Indigo. Can you give me some tips if there is the possibility to use displacement also with Indigo?
Post by Kram1032 » Fri Feb 23, 2007 3:55 am
Yummie, vanilla!!!!
zsouthboy
Post by zsouthboy » Fri Feb 23, 2007 5:37 am
Just bake the displacement map onto a mesh, silly :)
kepler
Post by kepler » Fri Feb 23, 2007 9:32 am
zsouthboy wrote:Just bake the displacement map onto a mesh, silly :)
Can you tell me how to do it? :?
Kachu
Post by Kachu » Fri Feb 23, 2007 1:21 pm
Add a displace modifier and use the image as a texture when you apply it.
Everyone else is doing it so : Core 2 duo E6600, 2 gb ram, Nvidia 8800 640 GTS and 250 gb hd
kepler
Post by kepler » Fri Feb 23, 2007 10:03 pm
Kachu wrote:Add a displace modifier and use the image as a texture when you apply it.
Thank you very much!!! :D
