DEV-thread - Blendigo v0.7 - material-editor-exporter
joegiampaoli
Post by joegiampaoli » Thu Feb 22, 2007 2:50 pm
in indigo directory there's a file called inifile.txt, open it and edit the section "save_igi" to true, like this:
"save_igi" "true"
Joe Giampaoli
My Indigo Gallery
paulo_gomes
Post by paulo_gomes » Thu Feb 22, 2007 2:54 pm
thank you joegiampaoli, it works! :D
but if i trie to run indigo within blender it doesn't :?
paulo_gomes
Post by paulo_gomes » Thu Feb 22, 2007 2:57 pm
sorry!!! it worked! my computer it's a BIT slow. thank you
:D :D :D
joegiampaoli
Post by joegiampaoli » Thu Feb 22, 2007 2:59 pm
ok, I was going to tell you to let it run a bit longer...
Good it works ;)
Joe Giampaoli
My Indigo Gallery
zuegs
Post by zuegs » Fri Feb 23, 2007 7:54 am
SMALL UPDATE
- removed surface compensation for lights - gain-value is equal to XML gain - use "efficacy" feature instead
And here some explanations for the previous implemented "EXTERNAL" material type :roll: :
If you like to use a special indigo-material that isn't implemented in the exporter-GUI, you can do this by including an external XML-file.
So write a XML scenedata file with your material inside with the correct material name as following:
<scenedata>
	<material>
		<name>my_material</name>
	</material>
</scenedata>
Then in blender create a material with the same name, open the Blendigo-GUI, select the material, set material-type to "External" and choose your external XML as filename.
When you then press the Render button, the exporter automaticly includes your external material-file and renders all possible indigo-materials :D :D
Post by Kram1032 » Fri Feb 23, 2007 9:21 am
I think, I've seen this already anywhere, but I'll write it anyway:
Can you either make your Exporter Name-adaptive to .sphere , .rect and .plane , or add a button for primitives?
(If Deus is fast enough, maybe 0.7 also has vegetation and landscape primitives :D)
zuegs
Post by zuegs » Fri Feb 23, 2007 9:45 am
hi kram1032,
ok, will have a look on this... not so hard... should be in tomorrow (i hope :wink: )
DaveC
Post by DaveC » Fri Feb 23, 2007 10:24 am
I have been using your exporter for one day. Your exporter is brilliant. I am currently rendering two blender monkeys with a skull, a blood layer and a skin layer. And, let me tell you, it's looking good. And it's all thanks to your exporter :D
cooler_inc
Post by cooler_inc » Fri Feb 23, 2007 10:27 pm
Hi
I tried to do BLEND material that contains NULL and Material with Alpha.
But after the export I get wrong code:
<material>
		<name>null</name>
		<null_material/>
	</material>
<material>
		<name>okun_tex</name>
		<diffuse>
			<colour>0.8 0.8 0.8</colour>
			<albedo_texture>
				<path>okun.jpg</path>
				<uv_set>uv</uv_set>
				<exponent>2.300000</exponent>
				<a>0</a>
				<b>1</b>
				<c>0</c>
			</albedo_texture>
		</diffuse>
	</material>
<material>
		<name>blend</name>
		<blend>
			<a_name>okun_tex</a_name>
			<b_name>blend</b_name>
			<blend_factor>0.5</blend_factor>
			<blend_map>
				<path>okun_0.jpg</path>
				<uv_set>uv</uv_set>
				<exponent>1.000000</exponent>
				<a>0</a>
				<b>1</b>
				<c>1</c>
			</blend_map>
		</blend>
	</material>
As you can see two components are wrong and I have to edit them manualy. They are:
I prepare the scene in this manner:
Two materials are applied to Mesh
The first one (lets call it "okun_tex") is DIFFUSE with Texture
The second (lets call it "blend") is BLEND with Mat.A:okun_tex and Mat.B:blend and Texture
Maybe this is not right method of preparing the BLEND material?
zuegs
Post by zuegs » Fri Feb 23, 2007 10:57 pm
hi cooler_inc
if you like to get this:
<b_name>null</b_name>
you should set "mat-B" value to "null" in the GUI.
Assign the "blend" material to your object (and force blender to save "okun_tex" material... not that it get lost)
Btw: if b=1 and c=1 your blend will completely fall to one side... because a*x^2+b*x+c will be >1 in any case :wink: (perhaps let c=0)
cooler_inc
Post by cooler_inc » Fri Feb 23, 2007 11:12 pm
I just changed Mat.B: to NULL and script crashed.
Console message:
NameError: Material "null" not found
Materials "blend" and "okun_tex" are already assigned to object.
Sorry for lame question but how to force blender for saving "okun_tex" material and what for?
zuegs
Post by zuegs » Sat Feb 24, 2007 12:23 am
hi cooler_inc,
oups... ok i see the crash... will fix this this evening, sorry about. But this will be the way how to use the BLEND.
You need just to assign the "belnd" material to your object, but you could assign the "okun_tex" as second material or you can toggle the small "F" button on the blender-material-panel to force that material get saved too (because otherwise blender only save the materials that are directly assigned to a object)
cooler_inc
Post by cooler_inc » Sat Feb 24, 2007 1:18 am
Thnx zuegs
Post by BbB » Sat Feb 24, 2007 4:15 am
Dunno if it's a bug or if I'm being stupid, or even if this has been said here already, but your largest lens aperture (F-Stop 1) seems to translate into a pinhole in the XML file. Of course, you can correct it there and put an aperture of 1 or just lower for a very shallow DOF but you might want to have a look at this.
Post by Kram1032 » Sat Feb 24, 2007 5:11 am
Thx! :D :D :D :D :D
