Render matched photo together with model
lape
Post by lape » Sat Apr 06, 2013 3:26 am
I'm still struggeling with photomatch.
What I did so far:
-modeled my scene with sketchup
-used photomatch to get the right perspective
-hit render and merge rendered perspective and real photo with photoeditor, deleted unessesary pixel from render
Attached is the quick result (yet there are no materials added).
The problem is: there are glass panes, and through these panes I would like to show the background picture.
Is it possible to render the scene together with the background picture? Unfortunately Indigo does not recognize this photo attached to sketchup... :?:
24 hours isn't enough
http://www.werkraum3d.com
Re: Render matched photo together with model
Post by OnoSendai » Sat Apr 06, 2013 3:46 am
I think the best solution for this problem is for rays that go through glass like in your picture to be 'background rays', for the purpose of the 'render foreground alpha' mode.
I'll try and get this working soon.
Post by StompinTom » Sat Apr 06, 2013 3:47 am
lape wrote:I'm still struggeling with photomatch.
What I did so far:
Why don't you just Photoshop it? There's a glaring white border between the rendered bit and the background image that should be cleaned up anyway. Just replace the black with the background photo and Photoshop a slight reflection or sheen onto it. There already seems to be a subtle reflection, so just take that bit of the background and 'Screen' or 'Add' it onto the glass, maybe at only 80% opacity or such, should do fine.
Post by StompinTom » Sat Apr 06, 2013 4:02 am
OnoSendai wrote:I think the best solution for this problem is for rays that go through glass like in your picture to be 'background rays', for the purpose of the 'render foreground alpha' mode.
Always the problem with alpha maps and glass materials. Is it possible to keep the reflections while making the transmission transparent?
Post by OnoSendai » Sat Apr 06, 2013 4:03 am
Yeah, should be, with enough hacks :)
Post by Zom-B » Sat Apr 06, 2013 4:36 am
OnoSendai wrote:Yeah, should be, with enough hacks :)
A feature that would push alpha rendering even further, and be really useful!
I would LOVE to see that in the 3.6 branch :)
lape
Post by lape » Sat Apr 06, 2013 6:16 am
seems I need a workaround for now... :?
cotty
Post by cotty » Sun Apr 07, 2013 9:26 am
The beginning of a search after a solution...
lape
Post by lape » Sun Apr 07, 2013 7:32 pm
cotty wrote:The beginning of a search after a solution...
For now I have a workaround for my problem:
I place a plane in sketchup behind my areas where I want the photo to be seen through the glass planes.
After I placed the plane I use the projection tool of sketchup to place the photo as a texture on the plane. This is not perfect because when I render the lighting on the texture is different, but here I have to use postprocess or adjust the brightnes of the texture.
Quite time consuming, but the only solution that works for me now.
Post by Pibuz » Wed Apr 10, 2013 9:51 am
Tricky indeed but it kinda works! :lol:
lape
Post by lape » Tue Apr 16, 2013 1:52 am
Here are the final shots, exterior and interior. Comments welcome! :mrgreen:
Voytech
Post by Voytech » Tue Apr 16, 2013 4:48 am
Looks great! Love the green grass next to snow effect ;)
Post by CTZn » Wed Apr 17, 2013 12:40 pm
nicely done lape.
lape
Post by lape » Wed Apr 17, 2013 9:32 pm
Thank you Voytech and CTZn! :D
JK
Post by JK » Thu Apr 18, 2013 11:59 am
Totally kewl mate but the shadow casting exactly on the line of the floor(i mean the tile of the texture line) makes it look like "too perfect". Try to dash it or smth ;) on more unperfect angle. That sticky poster on the windows is it a phisically based division or is it supposted to look like a stick on a glass(sorry if im not using the right term)? Dont get me wrong I really do totally and wesomely like what is there, but I just got "that feeling" ;).
Cheers!
Users browsing this forum: Ahrefs [Bot] and 22 guests
