Meterial Problem
4 posts • Page 1 of 1
M-Pixel
Meterial Problem
Post by M-Pixel » Fri Apr 05, 2013 3:45 pm
Hi everybody
For my new Projekt i need a Texture like this http://www.indigorenderer.com/materials/materials/1020
In C4D it does not work.
Can someone help me ? :)
Here my test :(
Cheers
Re: Meterial Problem
Post by Zom-B » Fri Apr 05, 2013 7:50 pm
The Saint-Gobain Glass stuff was just enabled by the last release, maybe there are still issues with internal rendering.
Thanks for the bugreport :)
galinette
Post by galinette » Fri Apr 05, 2013 8:47 pm
This material is a simple specular material with tabulated medium, it's technically not different from other liquids from the database, for instance. It works for ages, so I would suspect something else.
Here it looks like we have the reflection but absorption is negligible.
Check if your scene scale is correct, as the glass pane must have a thickness of a few millimeters in order to appear brown. If the thickness is much lower, it may appear as in your picture. As I don't know C4D, I'll let other help you with scale checking.
You can make a test : add to your scene a 10cm cube or sphere made of this material : http://www.indigorenderer.com/materials/materials/10. If it does not appear greenish, this means you have a scale problem.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
ENSLAVER
Post by ENSLAVER » Fri Apr 05, 2013 11:15 pm
If you can upload the problem piece of geometry it would make this really easy =)
Users browsing this forum: No registered users and 46 guests
