[REQ] Shadow Catcher material...
Post by zeitmeister » Thu Feb 28, 2013 1:47 am
Hey Ono,
just coming up again with an old request... :mrgreen:
Re: [REQ] Shadow Catcher material...
Post by Zom-B » Thu Feb 28, 2013 1:48 am
Now maybe even easier to realize since we have some proper alpha rendering mode?!
Post by OnoSendai » Thu Feb 28, 2013 2:11 am
How is this shadow catcher hack supposed to work again?
vis4arch
Post by vis4arch » Thu Feb 28, 2013 2:27 am
+1
Best for photo montage renderings.
all the best,
tamas
berg8 - werbeagentur
. design . web . marketing .
Post by Zom-B » Thu Feb 28, 2013 2:27 am
It should be a tag or material for a (free to define) ground mesh that only gets "colored" by shadow rays.
Actually its the renderpass "shadows" for that object only or so...
Post by zeitmeister » Thu Feb 28, 2013 2:45 am
Yip.
galinette
Post by galinette » Thu Feb 28, 2013 4:28 am
OnoSendai wrote:How is this shadow catcher hack supposed to work again?
This would be a full shadow pass mode associated with a shadow material.
If the second eye vertex (first being camera) is not hitting a shadow material -> render white
If this is a shadow material -> render the resulting radiance divided by shadow material albedo.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by OnoSendai » Thu Feb 28, 2013 4:40 am
Etienne
That could work somewhat. Would only really make sense for Lambertian shadow material.
Also I don't know if the workflow is good as you would have to render out a separate shadow pass and composite together.
galinette
Post by galinette » Thu Feb 28, 2013 6:31 am
OnoSendai wrote:That could work somewhat. Would only really make sense for Lambertian shadow material.
Yup, forgot to tell that
OnoSendai wrote:Also I don't know if the workflow is good as you would have to render out a separate shadow pass and composite together.
I thought this was the request. There are other 1-pass solutions with envmaps, but it's very impratical for unbiased renderers.
Post by OnoSendai » Thu Feb 28, 2013 6:32 am
I will try an approach something like this. Basically I will define the 'unshadow fraction' to be something like reflected occluded luminance divided by reflected unoccluded luminance.
Post by OnoSendai » Thu Feb 28, 2013 6:50 am
teapot under Uffizi probe
Post by zeitmeister » Thu Feb 28, 2013 6:50 am
It would be great as a pass, for sure.
But it would also help a lot as a shader!
Imagine just placing your model in front of a backplate and assign that shadow material to a floor... ready.
I really would appreciate that option!
Post by OnoSendai » Thu Feb 28, 2013 7:13 am
zeitmeister wrote:It would be great as a pass, for sure.
Why did you have to wait until I implement it the other way before you say how you want it? sigh.
Post by Zom-B » Thu Feb 28, 2013 7:34 am
OnoSendai wrote:Why did you have to wait until I implement it the other way before you say how you want it? sigh.
Just because you are so fast and nobody expected to see some results within days ^^
Another big benefit would be Background replacement via a HiRez image to be done directly in Indigo for fast composition, without doing 1001 renderings in Indigo and putting stuff together in PS...
Post by OnoSendai » Thu Feb 28, 2013 7:36 am
Zom-B wrote:
OnoSendai wrote: Another big benefit would be Background replacement via a HiRez image to be done directly in Indigo for fast composition, without doing 1001 renderings in Indigo and putting stuff together in PS...
This can be done with a background plate in the scene directly right?
