EnvMap + (fake) Sun Tutorial
Re: EnvMap + (fake) Sun Tutorial
Hi folks!
Can you assist me to have crips shadows??
Etienne Say in 2010 that's a common problem with the exr that they do not have enougth dynamic range between sun pixel and the other one.
He propose to do something with photoshop.
I never do something like that with my friend photoshop! First toshop poorly open my EXR file!
Then when i try to pickup some pixel info.... i don't know how to read it!
normal pixel:
http://img11.hostingpics.net/pics/92543 ... 32bits.jpg
sun pixel:
Ok i have an "intensity slot" but it's about a 3,41 factor, not 30000/100000!!!
how to putting it there?
By the way, the maximun parameters for that is 20.
And as toshop say, i need to transform my pictures into 16bits by layers to edit it?
But if i do that i fall all the interest of an exr file no?
normal pixel:
sun pixel:
errare humanum est
Simply create a "artificial sun" over yours by doing a circle selection and filling it with foreground color.
That color needs to be white with Intensity from 7 to 15, depends on how you like it most.
The artificial Sun shouldn't be to small btw, otherwise Indigo gets trouble sampling it.
Thank you for your help Zom-B!
I created my own exr for a sunny day with tiny clouds
my clouds was build by brush in 16bits, then i put a sun and after i changed the mode and retreived my selection of my sun.
I finally fill this selection by a +7 color.
It's hard to explain but when i try to do much more than 7 indigo render a strange picture.
All my other pixels was at 0
I made this texture to help me to use the Z orientation, because use radian is not natural for me, maybe it can help someone so i share it here:
http://www.hostingpics.net/viewer.php?i ... 0ruler.jpg
You can save it in exr or no and put it in background, usually the sun is in the middle of the pic, so the values on the horizon can help you to correctly orient your sun for your subjet.
errare humanum est
in my test quite some time ago, the sun turned black once I raised the brightness over +15.Jay-ko wrote:It's hard to explain but when i try to do much more than 7 indigo render a strange picture.
I should redo some test with actual version and see what happens.
If you get strange output, maybe try to raise the scale of your sun disc, that should speed up rendering and also make the shadows not super perfectly sharp, but with a little softer edges
It's better to work in 32 bits. However, only a recent photoshop (CS5 I think) added proper support for 32bit editing.Jay-ko wrote:Thank you for your help Zom-B!
I use a +14 intensity value for the sun. For a 16384x8192 envmap, the sun should be 22 pixels high. Width will vary between 22 near the horizon (sunrise/sunset) and increase with sun elevation in 1/cos(elevation), which means that at 45° elevation it is about 31 pixels wide and 32 pixels high, making an ellipse.
With these values, and a blackbody base emitter of 6500K , gain=1E-5, you will have roughly correct renders. Decrease sun disc intensity if the shadows are too dark, and vice-versa. Don't make your tests with reinhard, as you may end with much too bright or dark environment, causing numerical issues.
The best way is:
- Make some renders with indigo sunsky, camera tonemapping, and adjust your camera shutter and aperture to have correct result.
- Keep the camera and tonemapping settings, and switch to your envmap, with 6500K 1E-5 base emitter.
- Your envmap ground should be roughly correctly exposed when opened in photoshop without adjusting the display exposure
- Adjust your sun disc values with photoshop with trial and error, keeping the same camera settings in Indigo
- Work in 32bit with photoshop! The intensity>7 error is likely to be a 16bit limitation
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
- wlf_alex
Tell somebody, because I'm so confused! The method "EnvMap + (fake) Sun" or "EnvMap + Sun" still relevant? Or Indigo now has a mode to render "EnvMap + Indigo Sun" lighting?
regards...
regards...
Yes, Indigo has nowadays a method to render HDRi and overlay the sun on it, using the "SumMaterial".wlf_alex wrote:Tell somebody, because I'm so confused! The method "EnvMap + (fake) Sun" or "EnvMap + Sun" still relevant? Or Indigo now has a mode to render "EnvMap + Indigo Sun" lighting?
Sadly it isn't implemented in C4D exporter atm (Blendigo has afaik support for that feature!) :/
here some example code if you wanna put hand on the igs:
You can set up a background material that is a sum of both the sun+sky mat (with sky turned off) and an env map, like so:
<material>
<name>env_map_material</name>
<diffuse>
<texture>
<uv_set>albedo</uv_set>
<path>uffizi-large.exr</path>
<exponent>1.0</exponent>
<tex_coord_generation>
<spherical>
<rotation>
<axis_rotation>
<axis>0 0 1</axis>
<angle>1.6</angle>
</axis_rotation>
</rotation>
</spherical>
</tex_coord_generation>
</texture>
<base_emission>
<constant>
<blackbody>
<temperature>6500</temperature>
<gain>0.000001</gain>
</blackbody>
</constant>
</base_emission>
<emission>
<texture>
</texture>
</emission>
</diffuse>
</material>
<material>
<name>sunsky</name>
<sunsky>
<sundir>1 0 1</sundir>
<turbidity>2</turbidity>
<enable_sky>false</enable_sky>
<sun_layer>1</sun_layer>
</sunsky>
</material>
<background_settings>
<background_material>
<material>
<name>background</name>
<sum>
<mat>
<mat_name>sunsky</mat_name>
<weight>
<constant>1</constant>
</weight>
</mat>
<mat>
<mat_name>env_map_material</mat_name>
<weight>
</weight>
</mat>
</sum>
</material>
</background_material>
<emission_scale>
<material_name>background_material</material_name>
<measure>luminance</measure>
<value>8000</value>
</emission_scale>
</background_settings>polygonmanufaktur.de
I forgot to mention, but the "Intensity" parameter in photoshop HDR modes is an EV stop value, which means a power of two.Jay-ko wrote:Hi folks!
This means Intensity=+14 equals a factor of 2^14 = 16384.
Stupidly, in the "32-bit value" RGB values of the color picker, photoshop clamps the displayed value to 20.0, which is a simple display bug, since the good values such as 16384 are used when painting with intensity = 14.
- wlf_alex
Many thanks for the reply, Zom-B! But I do not know much ISL. I would be very grateful if you could show an example of how to use this feature. Was not able to use your "EnvMap + (fake) Sun Tutorial" because it was not possible to combine the shadow of the EnvMap and "artificial sun"
regards...
regards...
That is no ISL but simple IGS scene code (xml based) to be put by hand in your scenewlf_alex wrote:Many thanks for the reply, Zom-B! But I do not know much ISL
So this is actually your example scene code.
I don't really get what you want to say by that?wlf_alex wrote:Was not able to use your "EnvMap + (fake) Sun Tutorial" because it was not possible to combine the shadow of the EnvMap and "artificial sun"![]()
best to place the artificial sun over the existing (weak) one in the HDRI, so new sun & shadows are plausible with the displayed background.
- wlf_alex
Yes, it came out! It was necessary to raise the "sun" as high as possible above the scene.
But I do not know anything about IGS code. What does it do and how to use it? So I think that this opportunity does not exist for me.
PS And it is strange that there is no detailed description of this feature!
IGS: Indigo Scene
it's nothing but the scene description, listing objects, materials and so on. There can you change all the scene values, even some that the GUI would not expose.
An IGS file can be opened with any text editor.
For instance, an IGM can be thought of as an excerpt of an IGS.
Users browsing this forum: No registered users and 71 guests
