First try with SkIndigo
Re: First try with SkIndigo
It sadly seems quite clear: you have filled all of your RAM.
How much have you installed?
The Error Log tells ya that the GPU RAM isn't enough to fit your scene (models) in.
Try to use instancing for trees and other models to reduce RAM usage of the scene.
I have a GeForce GTX 285 with 1024MB RAM.
The tree and the pebbles are external obj meshes.
24 hours isn't enough
http://www.werkraum3d.com
Well external or not, while rendering they need to be loaded into (GPU) RAM, and I have no idea how Skindigo works here regarding instances.
Don't worry about the samples/ pixel rate. Between render modes these are not comparable!
The reason that only path-tracing is GPU supported is that path-tracing is a brute force method with a relatively simple sampling algorithm. The other methods use more effective sampling method, so given on a particular scene you get a cleaner picture much quicker, even though the SPP is not so high.
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Looking at the rendering, I am not even sure that for the small lamps you need to follow a bulb-inside-glass approach. You could try to remove the bulb and make the Glass cylinder the light source.
But the Lampshade (Reflection s) are so sweet, would be a shame to drop themHeadroom wrote:Looking at the rendering, I am not even sure that for the small lamps...
- xxx.jpg (25.32 KiB) Viewed 7430 times
Right! I was talking about the little lamps in the outdoor shot with the gravel pathway.
Here is my next try to set up the night scene. Can't get rid of the fireflies, though it rendered about 22h and has 8500spp, supersample set to 3. Render method Bidir Path Tracing.
It's getting better.
Indigo offers several rendering modes, each with strengths and weak points. GPU Path tracing is for speed, but some scenes will use a more robust method.
This scene wants MLT. It will "spread" rays, including fireflies. Highly recommended.
+1CTZn wrote: This scene wants MLT. It will "spread" rays, including fireflies. Highly recommended.
you are so right!
now with MLT and some changes for material
Looking really good!
thank you... I think I've fallen in love with IndigoOnoSendai wrote:Looking really good!
- LithiumDesign
night scene looks great!!
reflection bit too much on the wood? love the frosted glass on the top walkway and the texturing on the concrete - tried using a EXR environment? (EDIT: removed links --admin)
now i wanna know whats in the building on the left
