would that not require several thousand polies? I was thinking if you could generate an alpha map that vaguely represents a cloud and apply it to an oval shape, that would fake a (possibly) decent cloud with not to terribly much overhead.OnoSendai wrote:Deus.. I had an idea for how to do volumetric clouds for now:
you could build them out of spheres
e.g. randomly generate a whole lot of spheres, with a cloud shape density somehow.
Make the material a specular.
Make the medium a basic medium, IOR = 1 so no scattering will occur at interface.
The scattering coefficient should be wavelength independent i think (clouds are white).
phase function should probably be forwards scattering Henyey Greenstein (e.g. g = 0.
Absorption should be very small, or zero.
Make sure each sphere refers to the same medium (same medium name), that way they will merge when they overlap.
Indigo World Alpha (socks knocking time)
Yes i know, my spelling sucks
You know CTZn I know how to make 3d noise. Thats not the issue. The problem is what particles to chose and if there is optimizations to be done + to give good constraints on the cloud to give them nice look and also to get good materials.
There has been a ton of research on the subject there are plenty of programs and you get a million hits on google so please you dont need to educate me
The point of indigoworld is two
1) To be able to do things without any external software
2) To keep me busy
2) To keep me busy
Maya internal render, I just did them for demonstration purposes. Nothing changes from one image to the other but noise type. In this case clouds are not generated by dynamic (Navier-Strokes) simulation, only a texture carves the medium.Where are the images from CTZn?
Container Properties, friendly
Nodes::fluidShape, for techies
Maya help, with frames. Go under:
Using Maya > Dynamics and Effects > Fluid Effects > Texturing and shading fluids.
Deus, that was nothing personal, you guys are talking about clouds right here and I give my two cents to the mass...
