Mac Indigo Renderer Permissions
Can the permissions on the Mac version of Indigo Renderer be changed (I'm sick of having to change them for deployment in our computer labs).
The current setup it fine if you're an admin or single user, but if the app has been deployed by an admin, no other standard users can open it as is!
I'm no developer, but I'm guessing it's good practice to have applications like this executable for all local users on a given system.
Re: Mac Indigo Renderer Permissions
...and there still needs to be a writable folder within the Indigo app if exporting from Sketchup with the Skindigo plugin (Indigo.app/Contents/Resources/renders).
Not sure who needs to address that, but it seems like a bad idea... instead, have that renders folder created in the user space, or /tmp folder.
Thanks for the reports,
We'll try and fix these soon.
- zeitmeister
+1 for a custom Indigo temp folder!!!
Extremly useful for easily cleaning nodes... we had this issue recently.
Ein Suchbild ^^zeitmeister wrote:+1 for a custom Indigo temp folder!!!
- zeitmeister
Tja, helau dann wohl... Uäh.
Muss weg...
Muss weg...
Cinema 4D R11.5 Studio
http://www.impulse-arts.org/
Facebook
Hi,AdminHam wrote:...and there still needs to be a writable folder within the Indigo app if exporting from Sketchup with the Skindigo plugin (Indigo.app/Contents/Resources/renders).
You can set the render folder in the SkIndigo Render Settings, Output section, Image Path control.
If you set that to a local user directory presumably it should work?
AdminHam:
Could you please try with the latest SkIndigo: http://www.indigorenderer.com/forum/vie ... 17&t=12542
and tell me if there are still permissions problems?
Thanks.
Thanks.
The permissions on Indigo on OS X should be fixed now, in the 3.6.20 release: http://www.indigorenderer.com/forum/vie ... =1&t=12560
