Make sure that the skull is a well closed volume in order not to waste sss samples within.FakeShamus wrote:Copied the head and scaled it down, trying to give it even space all around. then cut of the ears and nose and dug out some eye sockets. Made it a dark red diffuse. The SSS takes a long time to converge with this material, any tips to speed it up?OnoSendai wrote:Good stuff!
How did you do the skull?
I would make it a light, yellowish grey because below the dermis is the superficial fascia. I'm not sure that assigning the skull a phong material would render faster but it could be more accurate.
Also, instead of scaling the modified face (ie skull), it can simply be displaced inwards for 2-3 mm, that would be consistent.
Best head render so far Fakeshamus !
