Indigo Renderer 3.6.2 Beta Release
Re: Indigo Renderer 3.6.2 Beta Release
Post by Zom-B » Thu Jan 03, 2013 9:19 pm
zeitmeister wrote:Uhm... interesting; what is the difference?
Maybe some 0-100% slider vs the exponent value...
Post by OnoSendai » Thu Jan 03, 2013 10:41 pm
Roughness varies from zero to one. Zero = no roughness = completely smooth. 1 roughness = max roughness.
Post by CTZn » Thu Jan 03, 2013 11:20 pm
It's an obvious bug but I'd rather have it mentioned: 3.6.2 crashes when a camera is changed to spherical in the GUI.
Post by CTZn » Fri Jan 04, 2013 12:03 am
CTZn wrote:It's an obvious bug but I'd rather have it mentioned: 3.6.2 crashes when a camera is changed to spherical in the GUI.
Mmh perhaps only when it is running a scene that didn't provide UID's ?
Post by Zom-B » Fri Jan 04, 2013 12:27 am
just recently tried that feature using the GUI and it worked nicely.
Only thing my resulting 360 image has is some imperfect edge on the sides, I used another hdri to light the tested scene and here that (minimal) cut is visible. I try to get some better visible example here.
Afaik Indigo cuts some pixels on the edges of the image, there could be the reason for it:
	Image width: 1280 px
	Image height: 720 px
	Internal image width: 3864 px
	Internal image height: 2184 px
Example for a render with SS @ 3, the 4 pixels extra width internally used could break the perfect 360 experience.
Post by OnoSendai » Fri Jan 04, 2013 12:43 am
Works fine here (on trunk at least)
Post by OnoSendai » Fri Jan 04, 2013 12:48 am
This is a known bug, will fix soon.
Post by OnoSendai » Fri Jan 04, 2013 5:57 am
Fixed the spherical tiling problem for the next release (3.6.4)
Post by CTZn » Fri Jan 04, 2013 6:22 am
Yes, it worked for me too from the material test scene as initialised by Indigo, however I could reproduce the crash repeatedly using a scene with a thin lens model exported by mti. I'm attaching the PIGS below, it's still happening with it.
brute_advLeaf_Crash on changing the camera type to spherical.pigs
(5.44 MiB) Downloaded 321 times
Users browsing this forum: No registered users and 103 guests
