Coating material tests
Post by OnoSendai » Thu Nov 29, 2012 10:49 am
Thought I'd make a new thread for test renders.
First off:
Interference from a thin coating, where the coating thickness is controlled with an FBM shader.
The substrate material is a somewhat rough metal.
All the rainbow colours come from light interfering with itself as it passes through the dielectric coating, which is a few micrometres thick.
A bit similar to one of Etienne's materials: http://www.indigorenderer.com/materials/materials/1065
Re: Coating material tests
Post by OnoSendai » Thu Nov 29, 2012 12:03 pm
Using a more accurate interference model plus turbulence noise:
Post by pixie » Thu Nov 29, 2012 12:31 pm
Owesome ono is awesome! :o
Post by OnoSendai » Fri Nov 30, 2012 2:47 am
Another one, with tweaked interference code:
Post by Zom-B » Fri Nov 30, 2012 3:50 am
I'm looking forward to play with that coating feature!
Only thing that kind is quite scary here is the SDS noise after 31min and 2500 samples/px -.-'
Post by OnoSendai » Fri Nov 30, 2012 4:07 am
Yeah I'm not sure if the noise is a problem with the new coating material or not. Seems like it may be.
Post by Pibuz » Mon Dec 03, 2012 3:29 am
The coating material is looking cool!
I see it reproduces some kind of rainbow-y effect on the surface it is applied to: is it something depending from a specific parameter? For architectural mats I'd use coatings for varnished floor mainly, but they don't have such rainbows :lol:
Post by Zom-B » Mon Dec 03, 2012 3:41 am
Pibuz wrote:I see it reproduces some kind of rainbow-y effect on the surface it is applied to: is it something depending from a specific parameter? For architectural mats I'd use coatings for varnished floor mainly, but they don't have such rainbows :lol:
That test have some special ISL code in the coating that creates that effect, its not per default mate!
"Simple" coating looks like that: http://www.indigorenderer.com/forum/vie ... 37#p119037
Post by Pibuz » Mon Dec 03, 2012 3:47 am
..OPS! And I had already seen that! :lol: :lol: :lol:
Sometimes you guys can forget my questions.......... :?
Post by OnoSendai » Mon Dec 03, 2012 8:51 am
Hi Pibuz,
The thin-film interference will be optional - it will be a checkbox on the coating material UI.
Post by OnoSendai » Wed Dec 05, 2012 6:33 am
Testing absorption in the coating.
The red colour comes from the absorption of non-red light as light passes through the coating layer.
coating_with_absorption.igm
(1008 Bytes) Downloaded 462 times
Post by OnoSendai » Wed Dec 05, 2012 6:44 am
Here's the thin-film coated metal:
interference_coating.igm
(1.36 KiB) Downloaded 464 times
Post by OnoSendai » Wed Dec 05, 2012 6:45 am
Make sure you have 3.6.2 installed if you want to try out the above materials!
http://www.indigorenderer.com/forum/vie ... =1&t=12056
Post by CTZn » Wed Dec 05, 2012 9:13 am
OnoSendai wrote:Testing absorption in the coating.
To put it in other words, the material underneath the coating is a grey metal. Gorgeous.
Post by OnoSendai » Wed Dec 05, 2012 12:08 pm
Doing a bit of work on getting the coating material going with transparent substrate materials.
Coating material over diffuse - diffuse-transmitter blend can be used to create quite a nice 'fast-SSS' material:
