Hi there,
My exporter seems to get stuck on a material and won't export. In the past I have had a few similar problems, and just imported a different igm file into the material to fix it, but this time doing that is not working. What can I do to remove this material and get my file to export?
Thank you!
Note: I just reopened the file and now it is "stuck" on a different material. This is a huge file with lots of materials, is there anything I can do?
Ruby console:
Error: #<FloatDomainError: NaN>
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `round'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `add_normals'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `collect'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1582:in `collect'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1582:in `add_normals'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:424:in `build_mesh'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:141:in `build_active_mesh'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:756:in `export'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1921
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `call'
exporter stuck on material
Re: exporter stuck on material
Hi there,
try going to Window->Model info->Statistics->Fix Problems.
You probably have some bad geometry in your model that is messing with the export.
littlemissbridget
That did the trick!
Thank you so very much!
Users browsing this forum: No registered users and 65 guests
