Intermittent Windows 7 installation error
12 posts • Page 1 of 1
grey
Post by grey » Mon Nov 02, 2009 1:58 pm
I'm trying to install Indigo 2.0.12c 32-bit build on Windows 7, but
"The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail."
I'm running Win7 Ultimate 32-bit on an AMD Athlon 64 X2 Dual Core 5600+ with 4GB and miles of free disk space.
What am I doing wrong?
For what it's worth, the 2.2 beta drops the same error.
Jambert
Re: Intermittent Windows 7 installation error
Post by Jambert » Wed Nov 04, 2009 3:32 am
I never had problem with win7, still I use RC and now ultimate!?
Try to install last 2.2.5
Did you run install as administrator?
Juju
Post by Juju » Tue Nov 13, 2012 4:40 am
I get this error on my fiance's machine at home as well, I have tried to uninstall / reinstall a few times, using install file for 3.4 stable released last week. For what it's worth, installation ran fine on my machine, using exact same installer.
Her machine: Win7Pro x64, i7 930, 8 GB RAM, GTX 280
My Machine: Win7Pro x64, i7 950, 12 GB RAM, GTX 580
Hoping to get a resolution so I can use her machine as a render node...
Post by lycium » Wed Nov 14, 2012 12:41 am
I think this error could happen if you've manually copied DLL files around the system, eg into Windows/System32. Certainly the right DLLs are packaged with Indigo in the local directory, so this kind of conflict shouldn't happen if there aren't other conflicting DLLs hanging around.
Juju
Post by Juju » Wed Nov 14, 2012 2:11 am
hmmm, OK, don't know then, certainly have not copied DLL's around... :|
Juju
Post by Juju » Tue Nov 20, 2012 3:12 am
So how do I fix this? Any ideas? Do I have to do a repair installation of the OS or what?
Post by fused » Tue Nov 20, 2012 4:16 am
Please try installing the "Microsoft Visual C++ 2008 SP1 Redistributable Package".
32 bit: http://www.microsoft.com/en-us/download ... px?id=5582
64 bit: http://www.microsoft.com/en-us/download ... px?id=2092
This should fix the problem.
Kind regards,
Yves
Juju
Post by Juju » Tue Nov 20, 2012 4:34 am
thanks for the suggestion fused, I'll report back here if that solved the problem, am hoping it will
Post by fused » Wed Nov 21, 2012 5:40 am
Sorry I linked you to the wrong ones. The ones needed are apparently these:
32: http://www.microsoft.com/en-us/download ... aspx?id=29
64: http://www.microsoft.com/en-us/download ... x?id=15336
Juju
Post by Juju » Wed Nov 21, 2012 5:56 am
Good show, thx., I haven't had time to look at it again.
Post by fused » Wed Nov 21, 2012 9:45 am
Sorry, my bad. The installer I posted first also work (and contain the needed dlls included in the installers I posted second) and are recommended to be used over the second links (that installer has an issue with leaving temporary files around on the C: drive).
Regards,
Yves
Juju
Post by Juju » Wed Nov 21, 2012 11:24 pm
Thanks once again!
