bug - sun light
mario
Post by mario » Sun Feb 18, 2007 11:05 pm
The question is this: is possible to obtain realistic trees mapping in UV coordinates a photo with alpha channel on a transparent plane? Indigo can use the alpha channel (justo for the transparency).( I think no)
The other was a question about rendering time: how many time for render with Indigo?
La faccenda era questa: come si possono ottenere alberi realistici, mappando in UV su piano trasparente con Indigo? Indigo può riconoscere il canale alfa?
Io penso di no;quanto tempo per renderizzare quel'immagine?
manitwo
Post by manitwo » Sun Feb 18, 2007 11:42 pm
mario wrote:The question is this: is possible to obtain realistic trees mapping in UV coordinates a photo with alpha channel on a transparent plane? Indigo can use the alpha channel (justo for the transparency).( I think no)
dont know if i understood you right but these are test-renders i did when
the first 0.7 test version came out:
Post by Kram1032 » Mon Feb 19, 2007 12:22 am
Nice pics!
Just would be great to see such leaves from beyond, so that you can see SSS ;)
Post by OnoSendai » Mon Feb 19, 2007 12:25 am
cool tree!
mario
Post by mario » Mon Feb 19, 2007 4:19 am
Wooow!!!!!!!
What's the method for obtain this?
Thanks
Mario
Post by CTZn » Tue Feb 20, 2007 5:05 am
Arbaro is one of the methods ;)
manitwo
Post by manitwo » Tue Feb 20, 2007 5:55 am
mario wrote:What's the method for obtain this?
Thanks
Mario
sorry, missed your question.
i used OBAN (plugin for c4d). Afaik someone made it working for max too (google for MOBAN).
mario
Post by mario » Tue Feb 20, 2007 7:40 am
Thanks!!!
mario
Post by mario » Tue Feb 20, 2007 7:41 am
Thanks!!!!
Users browsing this forum: Ahrefs [Bot] and 39 guests
