[REQ] Transculency
12 posts • Page 1 of 1
dcm
[REQ] Transculency
Post by dcm » Thu Sep 20, 2012 1:17 am
Possible to add transculency controlled by color and weight map ? Or something similar ?
Or maybe diffuse transmitter controlled by weight map ?
Re: [REQ] Transculency
Post by OnoSendai » Thu Sep 20, 2012 4:15 am
Hi Dcm,
What kind of material are you wanting to make?
Post by Zom-B » Thu Sep 20, 2012 4:20 am
I could imagine some leaves that has thinner parts and thicker areas.
I try to get something like that by blending Phong & DT using a "thickness map"...
But doing so the "thiner" areas are getting less reflective... so its a trade-off :/
Would it be possible to have some "Phong Transmitter" material?!
Post by zeitmeister » Thu Sep 20, 2012 5:18 am
Hehe,
Ono is working on that, I heard... :mrgreen:
Post by CTZn » Thu Sep 20, 2012 6:22 am
The luminosity of the diffuse transmitter texture acts as the weighting parameter if I'm correct, in wich case hue can be considered separately.
galinette
Post by galinette » Thu Sep 20, 2012 7:02 am
Rather than blending phong with DT, you simply can blend phong with a blend of diffuse and DT (nested blend). Your diffuse color should have the same color as the phong.
The thickness would then controlled by the blending function of diffuse and DT.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by zeitmeister » Thu Sep 20, 2012 9:42 am
... righto.
Post by Pibuz » Fri Sep 21, 2012 11:09 pm
(you know that we know that you know you know we know)
(matrioska thinking mode: ON)
Post by zeitmeister » Sat Sep 22, 2012 12:07 am
:lol:
dcm
Post by dcm » Mon Sep 24, 2012 1:30 am
By my request i meant, that we should control transparency by weight map = faking simple plane into geometry with thickness with material.
Simply, imagine leaf, which have more thickness towards its center. Now, you can do leaf as "sheet of paper", homogenously transparent in all areas. Or im missing somethnig ? I just want to make leaf where i can control "dark transparent areas" by bitmap. In real life, every leaf have some thickness, transculency...but leaves are not transculent like sheet of paper, homogenously in all areas. There is kind of variation, how light is comming thru leaf and spreading inside of leaf.
good exaple
Post by StompinTom » Mon Sep 24, 2012 2:05 am
dcm wrote:By my request i meant, that we should control transparency by weight map = faking simple plane into geometry with thickness with material.
good exaple
Add a color texture to a diffuse translucent material, that will control the color of the translucency. Mix this with a diffuse material with your surface color. The BW mix map will determine the 'thickness' of your material. Mix this blend material with a phong 'surface' material to control reflection / sheen.
Someone already alluded to this setup, which lets you control the apparent thickness of the leaf with the first blend.
Post by Pibuz » Mon Sep 24, 2012 6:07 am
PLEASE PLEASE post a graphic scheme!
Sounds to me like you're trying to explain integral calculation without writing down a single number :lol:
Users browsing this forum: No registered users and 83 guests
