Indigo Renderer 3.4.7
Re: Indigo Renderer 3.4.7
Post by Pibuz » Tue Sep 18, 2012 9:50 am
..small thing I noticed: the camera shift parameter has no influence on the OpenGL preview window. Is it fixable?
Post by Oscar J » Wed Sep 19, 2012 1:05 am
OnoSendai wrote:
Oscar J wrote:Nice updates but...
When can we expect the "save material" feature to work in OSX? I was hoping it would be included in this release. :(
Hi Oscar,
We'll try and get this fixed next week.
Excellent, thanks.
Post by lycium » Wed Sep 19, 2012 1:50 am
Hi fbrunell,
GPU rendering is indeed unavailable from remote desktop etc, if it's the same device used to display. This doesn't really make a lot of sense to me (if it's not actually displaying anything...) but is a commonly observed issue in Windows. Perhaps this is what's making it find but not use the device.
Post by OnoSendai » Wed Sep 19, 2012 5:10 am
Silmä wrote:
OnoSendai wrote:Hi Silma, I don't think ZOm-B is at the diffraction limit yet.
With f/64 you have an airy disk with the diameter of 0.03-0.06mm. On 36mm sensor that means diffraction limited resolution of about 800px.
I might have calculated that wrong, though...
The fact remains, higher f-stop means more blurring if you use aperture diffraction. Real lenses are usually sharpest around f/8, where you have balance between bokeh and diffraction.
Here's a good site about the phenomenon: http://www.cambridgeincolour.com/tutori ... graphy.htm
Hi Silmä,
I checked the maths, and it seems you're right.
So maybe Zom-B is hitting the diffraction limit. The odd thing is, that 3.4.6 isn't blurred in the same way.
Zom-B: Can you please try rendering that image again with a much wider aperture, like f/8?
Cheers!
Post by Zom-B » Wed Sep 19, 2012 7:12 am
OnoSendai wrote:Zom-B: Can you please try rendering that image again with a much wider aperture, like f/8?
I rendered with f/16 sinze f/8 had way to much DOF Blur to talk about sharpness ;)
The AD image is way less blured, but still a little...
Post by zeitmeister » Wed Sep 19, 2012 11:23 pm
I think I've got a similar issue here.
Postpro AD is much blurrier than physical AD... plus, more glooming.
AD physical
AD postpro
Post by Pibuz » Wed Sep 19, 2012 11:33 pm
(I personally like better the effect of the postpro AD)
Post by Zom-B » Thu Sep 20, 2012 12:07 am
Nice to see some optical vignetting in your render Zeiti :)
Post by CTZn » Thu Sep 20, 2012 12:43 am
Keep in mind that the physical AD requires convergence, the gloom takes time to build up in this case.
Zom-B wrote:Nice to see some optical vignetting in your render Zeiti :)
What ? Is this an option yet ?
Post by Zom-B » Thu Sep 20, 2012 12:47 am
CTZn wrote:What ? Is this an option yet ?
The Glare from the Sun looks "morphed" so I thought its "in" already... and activated by default.. but: thinking != knowing
Post by zeitmeister » Thu Sep 20, 2012 12:59 am
It is indeed already automatically implemented if you choose physical AD!
Post by CTZn » Thu Sep 20, 2012 1:05 am
zeitmeister wrote:It is indeed already automatically implemented if you choose physical AD!
Is it !? Cool, I'll have to test that.
Reality beats fiction then !
Post by OnoSendai » Thu Sep 20, 2012 1:06 am
It is?
Post by suvakas » Thu Sep 20, 2012 2:40 am
AD is not saved to final PNG when Indigo gets closed.
Post by zeitmeister » Thu Sep 20, 2012 4:27 am
Uhm... working here, working here ...?
