CTZn just showen the code one post over mine ^^pixie wrote:Do you mind sharing the material Zom-B?
it's actually that material with some bump:
http://www.indigorenderer.com/materials/materials/1104
I thought it was applied on the bump material, but ii tried it kept getting error...Zom-B wrote:CTZn just showen the code one post over mine ^^pixie wrote:Do you mind sharing the material Zom-B?
Way too noob on this end to make it work :pCTZn wrote:For bump mapping just use the third line from the lerp.
The vec3 just before the column tells the returned type, a color in this case, or more generally a 3d vector.
