GLass Properties
GLass Properties
Hi. i'm trying do render with indigo, but i have a problema. I do not know what to do to get the glass without those defects. this is the example. please help me. Does anyone have a clue?
Re: GLass Properties
Yes, do not use PT (disable GPU acceleration, and use MLT or Bidir MLT)
Eclat-Digital Research
http://www.eclat-digital.com
And check Glass Acceleration on, it should be a good helper here.
GLass Properties
I think we should make GPU support illegal
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
i do everthing, but the glass continue the same. In material type what i chose??
If you want to get rid of all problems, you should choose the Thin Glass shader, ALTHOUGH IT IS NOT A REAL PHYSICS-BASED MATERIAL and it could lead to different kind of issues. BTW, just try it: it can work with flat surfaces. If the fireflies still apppear, it means that what causes you problems here is something else. Also lower the whites to 210 210 210.
Can you show us pictures? Because with MLT, the problem should at least look different, it cannot look the samescarto wrote:i do everthing, but the glass continue the same. In material type what i chose??
Etienne
