Vlado's renders
vl_dm
Vlado's renders
Post by vl_dm » Sun Sep 02, 2012 5:00 am
Hello, I opened this thread like others to post here.
The model is from the net. Hope you like it!
Regards,
Vlado
solarray
Re: Vlado's renders
Post by solarray » Mon Sep 03, 2012 12:33 am
Try to put it into a studio setup, to tweeak the materials. In your scene its hard to see if they are right. The image also looks a bit oversaturated.
vl_dm
Re: Vlado's renders
Post by vl_dm » Fri Sep 07, 2012 8:06 am
I put it in a scene environment :)) But can't get the motion blur working. I have only the wheels moving by now... May someone tell me how motion blur works in Maxigo.. Thanks in advance
Re: Vlado's renders
Post by suvakas » Mon Sep 10, 2012 6:52 pm
Enable motion blur and play with the shutter speed.
vl_dm
Re: Vlado's renders
Post by vl_dm » Mon Sep 10, 2012 8:16 pm
Thank you, I'll try.
vl_dm
Re: Vlado's renders
Post by vl_dm » Thu Sep 13, 2012 7:56 pm
It is not working. I set it to 8 seconds and it is the same. Does it work with 3ds max or only with other exporters because I think I saw only skindigo examples in the forum.
ENSLAVER
Re: Vlado's renders
Post by ENSLAVER » Thu Sep 13, 2012 8:02 pm
vl_dm wrote:It is not working. I set it to 8 seconds and it is the same. Does it work with 3ds max or only with other exporters because I think I saw only skindigo examples in the forum.
Edit: I just noticed if the object is attached (child) in the hierarchy it won't have moblur. To check: press H, and select Display > Display children - If the wheels are parented by something they won't have motion blur.
It works in IndigoMax if you don't want to change the parent/child hierarchy though it is only beta and you might find other bugs.
dcm
Re: Vlado's renders
Post by dcm » Fri Sep 14, 2012 9:20 am
nice bimmer
vl_dm
Re: Vlado's renders
Post by vl_dm » Sun Jul 14, 2013 4:56 am
Hello, this is my new wip. Only lighting and shading. I hope you like it!
Re: Vlado's renders
Post by lycium » Tue Jul 16, 2013 2:26 am
Good old AVP :D All it needs is a twisting passageway with aliens crawling on the walls...
vl_dm
Re: Vlado's renders
Post by vl_dm » Tue Jul 23, 2013 5:45 am
Here is an update this time with my model
Re: Vlado's renders
Post by zeitmeister » Wed Jul 31, 2013 7:06 am
Yeah!
vl_dm
Re: Vlado's renders
Post by vl_dm » Sat Mar 08, 2014 7:21 pm
A shark
Polinalkrimizei
Re: Vlado's renders
Post by Polinalkrimizei » Fri Mar 28, 2014 8:13 pm
I completely missed that one!
Great mood, the tinted water is awesome...
vl_dm
Re: Vlado's renders
Post by vl_dm » Tue Apr 08, 2014 11:25 pm
Thank you, Polinalkrimizei,
here is another one I made recently
Users browsing this forum: No registered users and 134 guests
