August 2012 Competition - Materials & Lighting
Re: August 2012 Competition - Materials & Lighting
Post by StompinTom » Sun Aug 19, 2012 5:07 am
Hey Yves, it seems that the .obj model has some objects with non-standard characters in their names, which is throwing off exporting from Blender. It's not a huge problem, just need to go through and rename the objects, but it'd be worthwhile to change that for the .obj model so people aren't caught unawares.
Post by fused » Sun Aug 19, 2012 5:07 am
vl_dm wrote:Ok, thank you anyway!
Oh I just remembered that the scene does have glass in the windows. It will render much faster when you remove the glass and the difference is often not even noticeable.
Post by fused » Sun Aug 19, 2012 5:08 am
StompinTom wrote:Hey Yves, it seems that the .obj model has some objects with non-standard characters in their names, which is throwing off exporting from Blender. It's not a huge problem, just need to go through and rename the objects, but it'd be worthwhile to change that for the .obj model so people aren't caught unawares.
Thanks for letting me know. Will fix it on monday.
vl_dm
Post by vl_dm » Sun Aug 19, 2012 5:10 am
I'll try it and post other WIP later
Post by CTZn » Sun Aug 19, 2012 10:53 pm
The native Maya OBJ plugin is choking:
// Error: line 0: OBJ file line 7114227: index out of range for face creation. //
And the 3ds file is... triangulated, of course.
Post by fused » Mon Aug 20, 2012 10:31 pm
CTZn wrote:The native Maya OBJ plugin is choking:
Is there no proper obj import plugin for Maya? :)
Post by fused » Tue Aug 21, 2012 12:15 am
Updated obj files with ascii only object names.
Also added the reduced obj file that was used for creating the SketchUp file.
Post by Oscar J » Tue Aug 21, 2012 6:36 am
Something is not quite right here... this is how the model looks after I import it (full res obj).
Post by Oscar J » Tue Aug 21, 2012 6:44 am
And this is the reduced obj model after importing. The old models didn't look this crazy. :(
Post by fused » Tue Aug 21, 2012 7:58 am
Oscar J wrote:And this is the reduced obj model after importing. The old models didn't look this crazy. :(
Ah, forgot one important step before saving the obj from the original scene. Reuploading :)
Post by Oscar J » Tue Aug 21, 2012 8:19 am
Thanks :). Tell me, are you using a sun+sky lamp only in your blue scene? I'm such a rookie when it comes to interior rendering, and I thought yours had realistic lighting.
Post by fused » Tue Aug 21, 2012 8:37 am
Oscar J wrote:Thanks :). Tell me, are you using a sun+sky lamp only in your blue scene? I'm such a rookie when it comes to interior rendering, and I thought yours had realistic lighting.
Yes, I used Indigo's sun+sky (the old sun+sky to be exact).
There are a few things to watch out for (I guess I should put these in the first post :) ) :
- Use exit portals when rendering this scene with sun+sky (or an environment map).
- When rendering with sun+sky (or an environment map), make sure you remove the glass from the windows. Sunlight(or generally small emitters) through glass is a tricky problem for unbiased renderers. Glass acceleration helps, but it will render much faster without the glass and the visual difference is usually not noticable.
Note that if you want to keep the glass, exit portals are not a good choice (as vl_dm has already noticed).
Also, here's a camera flash shot of my updated scene (Again, I am not competing, because I am staff. This is just for fun):
Post by fused » Tue Aug 21, 2012 8:49 am
Updated (and this time hopefully properly working) obj is available now.
Post by CTZn » Tue Aug 21, 2012 9:37 am
No luck for me, it's the exact same line popping again. At this point the object causing the error is named "bianco". With 4 UVs it must be a subdivided plane.
I think it might be safer to generate the obj file from blender. There are as many proper OBJ plugins than interpretations resulting but this one should cope well.
By the way, thank you Impulse for a great scene !
Post by CTZn » Tue Aug 21, 2012 10:17 am
As for the 3ds file as imported by Maya (using bonusTools), "bianco" is among the few mangled meshes with "zylin1", 3 5 and 7.
"bianco" has many small faces, including 8 lamina faces in the tv shelf block. The exporter may be able to overlook something about those ?
No biggie tho. Oh, the linear scale is not specified into the obj file d;
