August 2012 Competition - Materials & Lighting
tar_gniK
3D Software: 3ds Max
Re: August 2012 Competition - Materials & Lighting
Post by tar_gniK » Fri Aug 17, 2012 10:06 pm
Are you allowed to change camera angle or not...?
Post by fused » Fri Aug 17, 2012 10:09 pm
tar_gniK wrote:Are you allowed to change camera angle or not...?
Yes, you can choose the camera angle how ever you want. Also updated the rules to make it clear.
Post by fused » Fri Aug 17, 2012 11:23 pm
More prizes! Big thanks to Arroway textures!
Post by fused » Sat Aug 18, 2012 12:38 am
Another prize upgrade:
2nd place now also gets an Indigo Renderer instead of an Indigo RT :)
LithiumDesign
Post by LithiumDesign » Sat Aug 18, 2012 1:15 am
maybe it's just my PC specs but the scene is ridiculously laggy in 3ds 2010 :cry:
Post by fused » Sat Aug 18, 2012 1:16 am
LithiumDesign wrote:maybe it's just my PC specs but the scene is ridiculously laggy in 3ds 2010 :cry:
Yeah, it's rather complex :)
Feel free to simplify/replace any models with ones that are not quite as performance hungry (we are not going to judge by polycount :D ).
Post by Zom-B » Sat Aug 18, 2012 2:04 am
XD
The carpet seems to be the most "complex" mesh in that scene, simply disable it for smooth navigation ;)
Post by Pibuz » Sat Aug 18, 2012 2:22 am
..well..I bet!
Can the scene be provided without carpet, and have a separate obj for that?
(I know it is a strange request.........that kind of workflow could ease the use of the SU scene using an external reference)
vl_dm
Post by vl_dm » Sun Aug 19, 2012 4:21 am
Hello,
Here is my WIP. Sorry for the grainy image - this is with 5 hours bidirectional MLT. I hope you like it
Post by fused » Sun Aug 19, 2012 4:35 am
vl_dm wrote:Hello,
Looks cool :)
You should consider using exit portals: http://www.indigorenderer.com/documenta ... xit-portal
They help a lot in this scene.
Cheers!
vl_dm
Post by vl_dm » Sun Aug 19, 2012 4:45 am
I tried but it is slower than without them. Probably I miss something. Should I apply a kind of material on them. It says "The exit portal material should only be applied to one side of a mesh (e.g. a cube), otherwise it will lose its effectiveness.". I can not find the material. I make a plane with normal towards inside the room and give it the exit portal modificator. Is it enough?
Thanks
Post by fused » Sun Aug 19, 2012 4:48 am
vl_dm wrote:I tried but it is slower than without them. Probably I miss something. Should I apply a kind of material on them. It says "The exit portal material should only be applied to one side of a mesh (e.g. a cube), otherwise it will lose its effectiveness.". I can not find the material. I make a plane with normal towards inside the room and give it the exit portal modificator. Is it enough?
Thanks
Depending on which software you use it may not be a material type. Do you use Sketchup or 3ds Max? C4D?
vl_dm
Post by vl_dm » Sun Aug 19, 2012 4:58 am
I use 3ds max 9 and Indigo 3.2.14 - the demo version
Post by fused » Sun Aug 19, 2012 5:00 am
vl_dm wrote:I use 3ds max 9 and Indigo 3.2.14 - the demo version
Not sure how to exactly do it in 3ds max, but the way you described it sounded like it should do the trick :)
vl_dm
Post by vl_dm » Sun Aug 19, 2012 5:04 am
Ok, thank you anyway!
