bug - sun light
The question is this: is possible to obtain realistic trees mapping in UV coordinates a photo with alpha channel on a transparent plane? Indigo can use the alpha channel (justo for the transparency).( I think no)
The other was a question about rendering time: how many time for render with Indigo?
La faccenda era questa: come si possono ottenere alberi realistici, mappando in UV su piano trasparente con Indigo? Indigo può riconoscere il canale alfa?
Io penso di no;quanto tempo per renderizzare quel'immagine?
dont know if i understood you right but these are test-renders i did whenmario wrote:The question is this: is possible to obtain realistic trees mapping in UV coordinates a photo with alpha channel on a transparent plane? Indigo can use the alpha channel (justo for the transparency).( I think no)
the first 0.7 test version came out:
