Public alpha release of IndigoMax
dcm
Re: Public alpha release of IndigoMax
Post by dcm » Thu Jul 19, 2012 9:06 am
I tried it quickly with simple scene and HDRI is not working.
What is "fresnel scale" ?
Under indigo environment :
what is "base" and why there are 2 options for file input ?
for image lightning, what is "base" and why there is input for file ?
Under indigo texture :
Why there is input for file under MAP and why there is filename ? Also on bottom of dialog, there is format option and specify option.
I think its little bit chaotic now, i dont know how to use it. Check images and thanks for expalanation.
Stromberg
Post by Stromberg » Thu Jul 19, 2012 9:14 am
Yeah, I find many things confusing as well, I mean great to see some development here.
But people are actually paying to get a working project, If indigo was in beta it would be something else.
At least make some documentation so users can figure out how to use the plugin.
subpixel
Post by subpixel » Thu Jul 19, 2012 9:36 am
dcm wrote:I tried it quickly with simple scene and HDRI is not working.
What do you mean? How did you use it?
dcm wrote:What is "fresnel scale" ?
You might check this: http://www.indigorenderer.com/forum/vie ... ?f=7&t=817 or ask Nick.
dcm wrote:what is "base" and why there are 2 options for file input ?
"Base" stands for base-emission. There are map slots for setting base-emission and emission, which makes most sense with Indigo Spectrum.
dcm wrote:Why there is input for file under MAP and why there is filename ? Also on bottom of dialog, there is format option and specify option.
Indigo Texture takes might take one of two sources: texture map or direct filename. If source is texture map or file format is not supported it will be rendered on-a-fly before rendering using Destination settings.
That's about it.
dcm
Post by dcm » Thu Jul 19, 2012 9:39 am
i asked Zom-b and he said that fresnel scale is quite old and does nothing in new version.
subpixel
Post by subpixel » Thu Jul 19, 2012 9:48 am
Thanks for info. Once it will be removed from SDK I'll remove it also.
ENSLAVER
Post by ENSLAVER » Thu Jul 19, 2012 1:12 pm
Awesome, thanks subpixel. I will play with this tonight!
Just quickly:
Postprocess aperture diffraction works on all render modes, but non-postprocess aperture diffraction only works with BIDIR Off. I'm not sure if it's an Indigo or IndigoMax bug.
Indigo gives this error for exported scenes: Error: Scene parsing error: Found unexpected element 'camera_type'. (In element 'camera', around line 164, column 5)
tar_gniK
3D Software: 3ds Max
Post by tar_gniK » Thu Jul 19, 2012 7:03 pm
Question: if you are a current Maxigo user, can you move over to IndigoMax and everything stays as is? Or do you have to re-texture and set render parameters from scratch? I am guessing yes??
dcm
Post by dcm » Thu Jul 19, 2012 7:03 pm
you have to make everything from scratch
subpixel
Post by subpixel » Thu Jul 19, 2012 8:23 pm
ENSLAVER wrote:Indigo gives this error for exported scenes: Error: Scene parsing error: Found unexpected element 'camera_type'. (In element 'camera', around line 164, column 5)
Yes. As mentioned it uses SDK 3.4.4 so you'd need to get Indigo 3.4.4, though I'm not sure if it's public already. I can't do much about it, sorry.
Post by Zom-B » Thu Jul 19, 2012 8:28 pm
Simply removing that line by hand from the IGS should do the trick ;)
ENSLAVER
Post by ENSLAVER » Thu Jul 19, 2012 10:36 pm
Ah! I must have misread. Thanks SubPixel.
Post by CTZn » Fri Jul 20, 2012 3:32 am
subpixel wrote:I'm not sure if it's public already.
Heh, no. It didn't exist before you mentionned it :)
ENSLAVER
Post by ENSLAVER » Fri Jul 20, 2012 11:57 pm
I know big things like non-blocking/activeshade are probably higher up on your to-do list, but here are a couple of smaller things.
Multiple uv map modifiers on the same object (map channel 1, 2, 3.. etc) don't work.
Nk Data.
Particle Material.
Pflow motion blur error.
Moblur length does not change when duration/shutter speed is changed.
Environment skylight "captured-simulated" model renders as "original".
Exported scenes only show "background settings" when using sun sky, rather than sun/sky settings.
Standard max maps (checker/noise/etc).
Exit portals.
Material Import.
I would love for the color correct map to work even if it is only inside the IndigoTexture. ColorCorrect is so familiar.
ENSLAVER
Post by ENSLAVER » Tue Jul 24, 2012 2:52 pm
Playing with the Environment blend (SUN+EXR)
hcpiter
Post by hcpiter » Fri Jul 27, 2012 12:47 am
nice!
how did you use sky and sun in IndigoMax ? Where add sky as environment ?
