CoolColJ's test pics thread
Polinalkrimizei
Re: CoolColJ's test pics thread
Post by Polinalkrimizei » Tue Jun 12, 2012 8:25 am
By funny colors I meant this, but it is starting to clear up after 1 hour and 4000 spp finally... looks pretty artsy-fartsy!
Post by Zom-B » Tue Jun 12, 2012 8:49 am
That happens with non uniform SSS and is will disappear over time :)
Post by Headroom » Tue Jun 12, 2012 1:48 pm
I'd assume you rendered that with BIDIR MLT. If you use PT-MLT the "noise" will turn monochromatic an will be less annoying (IIRC :wink: ).
There is some reference to it in this thread:
http://www.indigorenderer.com/forum/vie ... ochromatic
Post by CTZn » Tue Jun 12, 2012 11:36 pm
Hey polinalkrimizei, thanks for the PIGS.
I was concerned about the way the water surface was defined as faceted. Depending on the exporter it may be possible to have a faceted object with separated faces, cases in wich the subdivision trick I depicted above might have helped.
But there was no such issue :) I really thought that the faceted water was an asset to your scene, but it's true that the sun reflections are not that elegant then.
Polinalkrimizei
Post by Polinalkrimizei » Wed Jun 13, 2012 5:40 am
Ok ok I got it now - I remember your thread Headroom but didn't think about it. I did use BIDIR MLT, as I had the impression it would light the ground of the pool faster than PT with MLT enabled.
And I'm sure the noise will go away one day - but my impression is that the coloured noise will strive to zero while render time strives to infinity! This one is at over 40k spp, I'll stop now and continue my render without sss.
As shown, Indigo's forum is awesome. I'll leave this thread to be CoolColJ's playground again.
CoolColJ
Post by CoolColJ » Wed Jun 13, 2012 11:32 am
Interesting I never had any issues with the SSS resolving, in these water renders, it was more the dispersion (cauchyB value) which caused the rainbow look. Unless the surfaces have problem finding the sun - something that MLT variants are just not good at unfortunately with bump map and displacement
CoolColJ
Post by CoolColJ » Sat Jun 23, 2012 4:37 pm
Putting together an Asus P9X79 3930k 6 core, 16GB system ontop of my old X58a-UD3R i7 930 @ 4 ghz, 12GB system as I type this - then sell off the parts I no longer need 8)
Ram is ridiculously cheap these days!
Hope to hit 4.5 ghz on air - benchmarks and render tests to come..... :wink:
So an extra 30% performance based on architecture and clock speed, + 50% from 2 extra cores = 80% faster? :o
CoolColJ
Post by CoolColJ » Mon Jun 25, 2012 3:12 pm
After much messing around, I finally have the system fairly smooth, except for booting off the SSD OS drive- definitely need a SP2 for Windows7...
Anyway the Intel 520 SSD is hella fast and so is the CPU 8)
I wonder how it compares to the i7 970 running at the same clock speed - because I am thinking of getting that for my old x58 system and revert back to that, as it can run my Intensity Shuttle video capture card, which is very finicky about USB3 ports! In any case, the extra 2 cores are worth the extra $$$
Don't have much overclocking knowledge with these Ivy Bridge CPU, so I let the motherboard do most of it for me :)
It can run at 4.5ghz in my setup, but will crash at 4.6ghz. So I run at 4.4 with a bit of headroom for summer.
Doesn't run too hot right now in winter, I have a nice positive pressure case Silverstone FT02 - see temps in desktop pic, at 17 degrees Celsius today. Add another 20 for summer peak and it's still well under thermal limits.
I get around 1.5 million samples/sec with the Pins test scene that comes with Indigo, running at 4.4ghz on the 3930k CPU.
With a simple outdoor scene, it flies, see pics below. The scene needs MLT to render well, as it has lots of reflections/caustics and has physical aperture diffraction.
The first few passes go by so fast, it's like a pure GPU renderer! :shock:
I would say it's pretty close to double the speed of my i7 930 running at 4 ghz....
All rendered for 6 mins each.
GPU mode over 5 million samples - doesn't tax the GPU too much even then... 46% GPU load
Path tracing 3.6 million samples - fast, but slow :P
MLT - fairly high sample rate, and overall convergence, but not as accurate as BMLT
1.5+ million samples
Bidirectional Path tracing 1.6+ million samples
Bidirectional MLT - the slowest smaples wise, but the fastest converger here 813+k samples
CoolColJ
Post by CoolColJ » Mon Jun 25, 2012 5:08 pm
Just tried v3.4.2 - and it's even faster across the board!
ie a BMLT render I'm doing now went from 800+k to 1000+k samples per second
edit - looks buggy though, no apeture diffraction happens....
edit2 - it looks like there is a bug in the Indigo renderer, when your tweaking the F-Stop, while the renderer is running. The render updates, and the exposure changes, but the value you enter doesn't reflect the render results of the aperture dispersion. because when you save the scene, quit, and reload Indigo+ scene, it renders differently
CoolColJ
Post by CoolColJ » Mon Jun 25, 2012 6:07 pm
CoolColJ wrote:Just tried v3.4.2 - and it's even faster across the board!
here are the bugs
v3.4.2 no diffraction and what are the red dots?
v.3.4 aperture diffraction with F16 on lens - red dots as well
Here I entered 128 into the F-Stop in Indigo, by typing it in, and then typing in 16 again to return it to the above scene, but it renders like it's at F-Stop 128, but with F16 exposure values. And you get this garbage on the walls
If I drag the F-Stop slider back to 16 then it seems to nullify the bug - it seems to happen with a few other values in Indigo as well, dragging the slider vs typing it in.
edit - it does seem to me Indigo does not has as much aperture diffraction as a real camera with the same settings. I mean having to go up to f128 to get them isn't exactly realistic :lol:
CoolColJ
Post by CoolColJ » Mon Jun 25, 2012 6:18 pm
see what I mean?
real camera have way more diffraction at the same fstop as Indigo - me thinks the simulation needs tweaking :wink:
Post by StompinTom » Mon Jun 25, 2012 8:34 pm
CoolColJ wrote:see what I mean?
Could be because it's a shitty lens, though :P Depending on lens / filter coatings, etc., cheaper lenses will flare way more.
Post by OnoSendai » Mon Jun 25, 2012 9:26 pm
Hi CCJ,
Can you please post (or email us) the scene with the red dots?
Non-post pro aperture diffraction is broken in updated bidir, will fix.
dcm
Post by dcm » Fri Jun 29, 2012 8:29 pm
i noticed problem with AD too when using Image
Post by Zom-B » Fri Jun 29, 2012 9:00 pm
CoolColJ wrote:real camera have way more diffraction at the same fstop as Indigo - me thinks the simulation needs tweaking :wink:
Maybe that (sadly still not released) Paper could be a good starting point:
Polynomial Optics: A Construction Kit for Efficient Ray-Tracing of Lens Systems
