how do I change width/height through command line?
Come here for help & support.
6 posts • Page 1 of 1
tupacodaman
Post by tupacodaman » Wed Jun 06, 2012 2:49 am
Hi everyone,
So I'm writing a script that will use this command
indigo inputfilename -o outputfilename -halt 3600
to go through a bunch of files I want to render and then save each image after it's rendered for an hour (the loops obviously aren't above, still working on that)
my question is: is there any command line function I can add to specify the width/height? I'd like to make each image 800x600. The files, by the way, were all exported with SkIndigo, but at different ratios. So it'd be great to just be able to make them consistent through Indigo
thanks in advance!
Re: how do I change width/height through command line?
Post by OnoSendai » Wed Jun 06, 2012 3:08 am
--settings "<width>100</width><height>100</height>"
tupacodaman
Post by tupacodaman » Wed Jun 06, 2012 3:40 am
hm, what is the syntax? I've typed in both of these and neither one works:
indigo --settings "<width> 800 </width> <height> 600 </height>"
inputfilename -o outputfilename -haltspp 600
indigo /home/davidmunoz/tarrlabdata/Tara/test/Kitchen_1A.igs -o /home/davidmunoz/tarrlabdata/Tara/test/Kitchen_1A.jpg -haltspp 600 --settings "<width> 800 </width> <height> 600 </height>"
thanks!
Post by OnoSendai » Wed Jun 06, 2012 4:28 am
Try it with indigo_console, it should work. I'm not sure if it works with the GUI executable.
tupacodaman
Post by tupacodaman » Wed Jun 06, 2012 8:55 am
hm, sorry, complete novice here. I'm using indigort with linux and I don't see indigo_console anywhere in the main indigort directory :( is that where it's supposed to be?
thanks though!
Post by OnoSendai » Wed Jun 06, 2012 9:39 am
It should be. Which Indigo version are you using? (3.0, 3.2 etc..)
