Hi everyone,
So I'm writing a script that will use this command
indigo inputfilename -o outputfilename -halt 3600
to go through a bunch of files I want to render and then save each image after it's rendered for an hour (the loops obviously aren't above, still working on that)
my question is: is there any command line function I can add to specify the width/height? I'd like to make each image 800x600. The files, by the way, were all exported with SkIndigo, but at different ratios. So it'd be great to just be able to make them consistent through Indigo
thanks in advance!
how do I change width/height through command line?
tupacodaman
Re: how do I change width/height through command line?
--settings "<width>100</width><height>100</height>"
tupacodaman
hm, what is the syntax? I've typed in both of these and neither one works:
indigo --settings "<width> 800 </width> <height> 600 </height>"
inputfilename -o outputfilename -haltspp 600
indigo /home/davidmunoz/tarrlabdata/Tara/test/Kitchen_1A.igs -o /home/davidmunoz/tarrlabdata/Tara/test/Kitchen_1A.jpg -haltspp 600 --settings "<width> 800 </width> <height> 600 </height>"
thanks!
thanks!
Try it with indigo_console, it should work. I'm not sure if it works with the GUI executable.
tupacodaman
hm, sorry, complete novice here. I'm using indigort with linux and I don't see indigo_console anywhere in the main indigort directory
is that where it's supposed to be?
thanks though!
thanks though!
It should be. Which Indigo version are you using? (3.0, 3.2 etc..)
