we released a new major version of Indigo for Revit containing many important improvements and bugfixes like full support for sections, phases and design options, texture conversion for Revit base materials and drastically reduced export time.
Indigo for Revit 3.2.13
* Fixed and improved browsing of online material database
* Corrected orientation of textures
* Now supports automatic conversion of textures from built-in Revit materials
* Fixed Phases, Design Options and Sections
* Camera field of view is now exported accurately
* Now respects the crop box of the selected view
* Now uses Indigo's new Sun & Sky
* Fixed problem with models being exported multiple times at the wrong position
* Improved material conversion for glass and metals
* Overall export time is now 5 - 10 times faster
* Added options for vignetting and network rendering to render settings
* Export status dialog does not freeze anymoreYou can download the Indigo for Revit installer packages from here: http://www.indigorenderer.com/revit/
It is also required that you update your Indigo installation to Indigo 3.2.13, which you can get from here: http://www.indigorenderer.com/forum/vie ... =1&t=11555
