hair and more
7 posts • Page 1 of 1
india
hair and more
Post by india » Sat May 05, 2012 6:26 am
how can i render hair or eyelashes or pretty anything that needs alpha/transparency channels? obviously i need the diffuse, alpha/transparency channel for the textures. but when i pick the diffuse option there is no option for alpha or transparency...
Re: hair and more
Post by PureSpider » Sat May 05, 2012 6:31 am
Use the blend channel and don't use another material to blend, then you will get transparency :wink:
india
Re: hair and more
Post by india » Sat May 05, 2012 6:34 am
fast response. wow thanks :) so use my texture for teh diffuse adn turn on the blend channel?
Re: hair and more
Post by PureSpider » Sat May 05, 2012 6:53 am
and put your alpha map in the blend channel, yes 8)
india
Re: hair and more
Post by india » Sat May 05, 2012 6:56 am
working good now.. im a fan of Indigo now. might be giving Vray the boot LOL :)
Re: hair and more
Post by Zom-B » Sat May 05, 2012 7:29 am
india wrote:but when i pick the diffuse option there is no option for alpha or transparency...
If you use a PNG with alpha, not in a separate channel, but simply a texture with transparency, then Indigo uses that :)
give it a try
india
Re: hair and more
Post by india » Tue May 08, 2012 7:40 am
give it a try
ah that worked :) had to make the png in Adobe but thats ok... thanks
