Indigo for Cinema 4D 3.2.12
14 posts • Page 1 of 1
Post by fused » Tue Apr 24, 2012 11:51 pm
CoolColJ
Re: Indigo for Cinema 4D 3.2.12
Post by CoolColJ » Thu Apr 26, 2012 12:45 pm
Been a while since I used the exporter.
Anyway i tried to render a scene with this new version, and I got an error message, which I never had before.
This scene uses my tabulated spectrum data for water.
Error: Scene parsing error: start_wavelength must be <= 0.7e-6 m (700 nm). (In element 'regular_tabulated', around line 198, column 25)
This is what the exported scene file reads as for the water medium
	<medium>
			<uid>9</uid>
			<name>MedWater with ISL displacement</name>
			<precedence>5</precedence>
			<basic>
				<ior>1.3300000429153442</ior>
				<cauchy_b_coeff>0.0030000000260770</cauchy_b_coeff>
				<step_size>0.1000000000000000</step_size>
				<absorption_coefficient>
					<constant>
						<regular_tabulated>
							<start_wavelength>0.0000000000000000</start_wavelength>
							<end_wavelength>0.0000000000000000</end_wavelength>
							<num_values>83</num_values>
							<values>0.03250 0.02640 0.02040 0.01800 0.01560 0.01350 0.01140 0.01070 0.01000 0.00940 0.00880 0.00790 0.00700 0.00600 0.00560 0.00520 0.00540 0.00610 0.00640 0.00690 0.00830 0.00950 0.01100 0.01200 0.01220 0.01250 0.01430 0.01300 0.01570 0.01680 0.01850 0.02130 0.02420 0.03000 0.03820 0.04620 0.04740 0.04850 0.05050 0.05270 0.05510 0.05940 0.06540 0.06900 0.07150 0.07430 0.08040 0.08900 0.10160 0.12350 0.14870 0.18180 0.24170 0.27950 0.28760 0.29160 0.30470 0.31350 0.31840 0.33090 0.33820 0.35130 0.35940 0.38520 0.42120 0.43110 0.43460 0.43900 0.45240 0.46900 0.49290 0.53050 0.62290 0.75220 0.86550 1.04920 1.26900 1.52530 1.96240 2.53040 2.76800 2.83380 2.84840 </values>
						</regular_tabulated>
					</constant>
				</absorption_coefficient>
			</basic>
		</medium>
It appears the exporter is not putting in the correct start and end wavelength numbers. Which are 100 and 700
The same medium output from an older exporter
    <medium>
        <name>MedWater_with_ISL_displacement_mid2</name>
        <basic>
            <ior>1.330000</ior>
            <cauchy_b_coeff>0.003000</cauchy_b_coeff>
                <regular_tabulated>
                    <start_wavelength>3.4e-007</start_wavelength>
                    <end_wavelength>7.5e-007</end_wavelength>
                    <values>0.0325 0.0264 0.0204 0.018 0.0156 0.0135 0.0114 0.0107 0.01 0.0094 0.0088 0.0079 0.007 0.006 0.0056 0.0052 0.0054 0.0061 0.0064 0.0069 0.0083 0.0095 0.011 0.012 0.0122 0.0125 0.0143 0.013 0.0157 0.0168 0.0185 0.0213 0.0242 0.03 0.0382 0.0462 0.0474 0.0485 0.0505 0.0527 0.0551 0.0594 0.0654 0.069 0.0715 0.0743 0.0804 0.089 0.1016 0.1235 0.1487 0.1818 0.2417 0.2795 0.2876 0.2916 0.3047 0.3135 0.3184 0.3309 0.3382 0.3513 0.3594 0.3852 0.4212 0.4311 0.4346 0.439 0.4524 0.469 0.4929 0.5305 0.6229 0.7522 0.8655 1.0492 1.269 1.5253 1.9624 2.5304 2.768 2.8338 2.8484</values>
        </basic>
    </medium>
CoolColJ
Post by CoolColJ » Thu Apr 26, 2012 1:23 pm
Were the camera values on export changed from older versions?
Because exporting some old scenes rendered way brighter than the same scenes files I already had.
I had to knock down the EV values by 5!
CoolColJ
Post by CoolColJ » Thu Apr 26, 2012 1:29 pm
Ok I think I spotted another bug
Exposure duration in C4D is at 0.05, but in the scene file it shows 20
<exposure_duration>20.0000000000000000</exposure_duration>
In an old copy of the same scene <exposure_duration>0.050000</exposure_duration>
CoolColJ
Post by CoolColJ » Thu Apr 26, 2012 3:39 pm
I forgot to add I'm using C4D R11.5
It would appear that some of the issues are because I'm loading scenes that use older versions of the Cindigo exporter
Post by Zom-B » Thu Apr 26, 2012 6:34 pm
CoolColJ wrote:Were the camera values on export changed from older versions?
CoolColJ wrote:Ok I think I spotted another bug
You answered your First question by the second "bug" you've found ^^
Indigos Exposure Duration is now seconds = 1 / value!
It still loads the "old" values when that variable was used different internally in old scenes, so you end up with a long exposure duration if ya had 0.05 seconds set before, since 1/0.05 = 20 seconds!
I also found that start/end bug in tabulated data usage, was reported silently some days ago...
Post by fused » Fri Apr 27, 2012 12:00 am
Hi CoolColJ,
I am sorry but you will need to reimport materials using the tabulated spectrum (or alternatively you could open the material in question in C4D and fix the start and end wavelength manually).
Cindigo 3.2.9.2
* Fixed remaining issues with regular tabulated. Might break existing materials (sorry) but is a big improvement over how it was.
CoolColJ
Post by CoolColJ » Fri Apr 27, 2012 10:19 am
Thanks
Are exports from this version of exporter compatible with Indigo V2?
It seems like if I have more than one version of Cindigo in the C4D plugins folder only one gets used, usually the earliest version
CoolColJ
Post by CoolColJ » Fri Apr 27, 2012 10:47 am
Another issue
With C4D R10, didn't try yet with 11 or 11.5, when I dragged the Sun position into the Indigo render settings environment sun direction, it worked OK. But when I changed the time, so Sun position, the changes didn't register in Indigo. Even when I redragged the sun object back onto the sun direction slot
user error or bug?
Post by fused » Fri Apr 27, 2012 11:29 am
CoolColJ wrote:Thanks
Exports from Cindigo/Indigo for Cinema 4D 3.2.9+ are not easily usable in Indigo 2.x, due to changes in the scene file format.
You can have only one version of any plugin installed at the same time.
CoolColJ wrote:Another issue
user error or bug?
Seems to work here (11.5). What kind of object did you use for the sun? C4D's sun object?
Will try in R10 in the office tomorrow.
CoolColJ
Post by CoolColJ » Fri Apr 27, 2012 5:41 pm
I used the C4D sun object. Nulls don't seem to work anymore
Post by fused » Sat Apr 28, 2012 12:32 am
CoolColJ wrote:I used the C4D sun object. Nulls don't seem to work anymore
Hi CoolColJ,
both the sun and null object seem to work fine here in R10. Note that I changed the behavior of the sun direction to not be the vector from the object to the scene origin, but to use the direction of the Z axis (blue) of the object set in the sun direction field (but that was quite a while ago, during 2.x iirc).
See attached scene:
Exit Portals and SunSky.zip
(657.1 KiB) Downloaded 357 times
If you still have problems to get it to work, could you send me a c4d scene file that has this problem?
Cheers!
pdavid
Post by pdavid » Sat Apr 28, 2012 5:46 am
hey
i am a new user of indigo full version
can you save a indigo matrial as matrial preset in cinema 4d browser.
because a got a bugreport from cinema 4d
cinema 4d 11.5|indigo renderer 3.x full|980x|node(1)2600k|node(2) 920
Post by fused » Sat Apr 28, 2012 6:34 am
pdavid wrote:hey
Hi pdavid,
this is a known issue and it is fixed for the next version. I will release it as soon as possible.
Kind regards,
Yves
Users browsing this forum: No registered users and 122 guests
