Blendigo (for Blender 2.62) 3.2.12.0
3.2.12.0
DOWNLOADS
ALL PLATFORMS: http://www.indigorenderer.com/dist/expo ... 2.12.0.zip
WINDOWS INSTALLER: http://www.indigorenderer.com/dist/expo ... taller.exe
NOTE: This exporter REQUIRES Blender version 2.62
Changes in this release:
* Fix regression regarding parented objects transforms
* Change default Phong IOR to 1.3
* Check validity of external materials during export and abort if not valid
* Adjust default OSX install path to match that given by installation instructions
MANUAL INSTALLATION
Unzip the archive. Move the extracted indigo folder into your Blender addons folder.
You should end up with <blender scripts>/addons/indigo/
Run Blender 2.6, go into User Preferences/Addons, and find the Render section. Locate the Blendigo entry
and enable the addon by clicking the little checkbox on the right.
INSTALLATION VIA BLENDER
Run Blender 2.6, go into User Preferences/Addons. Click the "Install Addon" button and choose the blendigo-2.5-3.2.12.0.zip file. The addon will be installed and shown to you, ready for activation.
If you are upgrading, be sure to choose the "Overwrite" option when selecting the .zip file.
You can easily check the installed version in the Addons panel. After upgrading/replacing I would strongly recommend restarting blender.
HINTS
Save your User Settings now to make Blendigo activate every time you start Blender 2.6.
Non-windows users will have to also fill in the "Path to Indigo" setting in the "Indigo Render Engine Settings"
panel. (Windows does this automatically from the information provided by the installer). Note that you should
specify the installation directory (or Indigo.app on OSX) for this setting.
YOUR FEEDBACK IS ALWAYS APPRECIATED
As with the current efforts to get Indigo 3.x as complete and user-friendly as possible,
please please keep reporting any issues you find with Blendigo - it is your feedback as
users and artists alone that push Blendigo forward into being the software that works for you.
DOWNLOADS
MANUAL INSTALLATION
HINTS
Re: Blendigo (for Blender 2.6x) 3.2.12.0
Hi Doug,
Because of the imminent release of Blender 2.63 (in release candidates stage right now), will the exporter work with the new version? I'm not sure if B-mesh was implemented in 2.62 already or if it's new as of 2.63, but I imagine that would break things... ?
I think there's a minor change relating to uv access for bmesh, but I honestly don't know much beyond that.
Yeah, Blendigo doesn't load with the 2.63 release candidate
Looks like the whole B-mesh shift has changed things.
Is the exit-portal (and null) material type missing or is it only hidden somewhere?
It's under mesh settings, on an individual object basis.Silmä wrote:Is the exit-portal (and null) material type missing or is it only hidden somewhere?
Not sure if this is known, but having more than one external material crashes export, or even having two objects with the same external material crashes export.
Doesn't work with 2.63 release either... When b-mesh compatible Blendigo can be expected?StompinTom wrote:Yeah, Blendigo doesn't load with the 2.63 release candidateLooks like the whole B-mesh shift has changed things.
southpawami
Ya... I've been having terrible luck with blendigo(using blender 2.62 and 2.63; both 64bit). A default scene with just a cube, a single light source, and a camera will give me an error saying no light source and not render. (skindigo works fine)
- Polinalkrimizei
Be sure to add a Hemi lamp to your scene, then you'll find all indigo's light related options in blenders lamp panel.
As soon as the Blender API settles down, we will add 2.6.3 support.HV wrote:Doesn't work with 2.63 release either... When b-mesh compatible Blendigo can be expected?StompinTom wrote:Yeah, Blendigo doesn't load with the 2.63 release candidateLooks like the whole B-mesh shift has changed things.
That's like saying when the universe's heat death nears, or when protons starts to decay, or when dark/zero point energy is strong enough to rip the quarks a part...OnoSendai wrote: ...As soon as the Blender API settles down...
Big problem
-Check validity of external materials during export and abort if not valid
I've problem when exporting external material, would be nice if it was possible to enable or desable the checking.
it's the same with all other materials, don't understand why
thx
Big problem
[Indigo 2012-May-22 11:26:28] Writing to ID classes in this context is not allowed: matP, Material datablock, error setting indigo_material_external.material_name
<scenedata>
<material>
<name>matP</name>
<diffuse>
<texture>
<path>/home/indigo/material/HDF.png</path>
<a>0</a>
<b>1</b>
<c>0</c>
<uv_set>default</uv_set>
<exponent>2.2</exponent>
<tex_coord_generation>
<uv>
<matrix>
1 0 0 1
</matrix>
<translation>
0 0
</translation>
</uv>
</tex_coord_generation>
</texture>
<albedo>
<texture>
</texture>
</albedo>
<random_triangle_colours>false</random_triangle_colours>
<layer>0</layer>
</diffuse>
</material>
</scenedata>thx
Hi
What is the difference between old and new external material?
thx
thx
Can't find environnement settings?? how to use background for rendering?
please help
please help
