problem rendering to displacement
SCHMUMS
Re: problem rendering to displacement
Post by SCHMUMS » Fri Apr 06, 2012 1:34 am
SAlut Adam,
désolé je n'avais pas vu… Après un long moment d'absence et manque d'apprentissage je me remet doucement dans le bain.
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
Post by Zom-B » Fri Apr 06, 2012 1:50 am
A normal map shouldn't be needed if your displacement is detailed enough.
If you have a separate map for bumpy details that are not covered in the displacement map, you'll have to use bumpmapping for that...
SCHMUMS
Post by SCHMUMS » Fri Apr 06, 2012 9:00 am
here is a quick rendering of my test dispalcement on my dragon.
I'll be able to work on this final displacement in zbrush.
To be continued
Zbrush 4
