Hello,
Im new to this forum, Ive recently noticed that when I now try to Render a view from Google Sketchup 8 I get this error, the renderer was working fine until i played around on the Advanced settings. Can anyone help with this issue? Thanks!
Failed For Reading??
Re: Failed For Reading??
Hi Ryan, welcome to the Forum
If you find any Problems, Bugs or issues the best idea is to grab the latest Indigo and Exporter version, the problem you have may already be fixed!
For Indigo its 3.2.9 (18 versions and 152 "release points" since the build you are using!!)
For Skindigo its v3.2.8
I hope that "fixes" the problem... if not, then report back
Unfortunately it didnt work i downloaded the two you linked and they didnt work at all (It wouldnt allow me to install to the correct place i.e. C:\Programe Files (86) ..... ) I also tried downloading the new version of indigo RT but that had the same error message.
Hi Ryan, would it be possible for you to send us this scene? If you could pack it as a .PIGS (from File -> Save As) and mail it to support@indigorenderer.com that'd be greatly appreciated, thanks!
