Indigo Renderer 3.2.7
8 posts • Page 1 of 1
Post by lycium » Tue Feb 07, 2012 4:06 am
This is a Beta release, intended to fix the crash reported by some AMD users in Indigo 3.2.6.
Indigo for Windows 32-bit:
IndigoRenderer_3.2.7_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.2.7_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.2.7.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.2.7.tar.gz
IndigoRenderer3.2.7.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.2.7_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.2.7_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.2.7.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.2.7.tar.gz
IndigoRT3.2.7.dmg
Changelog:
3.2.7
* Fixed crash on some AMD CPUs.
Re: Indigo Renderer 3.2.7
Post by Pibuz » Tue Feb 07, 2012 6:37 am
Hi guys!
I'm reporting a small bug with current version and Exit Portals: even if the render is NOT using the GPU (so NO plain PT), the image is completely black when I use the new sky model.
Everything is ok if with same settings I enable the former sky model.
Using Indigo 3.2.7, SkIndigo 3.2.5 and nVidia drivers 276.42.
ENSLAVER
Post by ENSLAVER » Tue Feb 07, 2012 1:56 pm
Pibuz wrote:Hi guys!
It does work for me with the new sky model, though in some modes (PT, PT+GPU, PT+MLT) it exhibits odd behaviour. Light comes out both sides of the portal (not just the direction of the normal) and in pure PT or PT+GPU it is really slow to converge.
It should work fine in a BiDir mode Pibuz?
Post by lycium » Tue Feb 07, 2012 2:24 pm
This is a confirmed bug and we're looking into it; thx for reporting Pibuz!
Post by Pibuz » Tue Feb 07, 2012 8:22 pm
In my experience, the image renders pure black if PT (or GPU) is enabled, even if the sample rate actually goes up. The same error shows up using BiDir too: the problem here seem to be generated by the combined use of EPs and new sky model; the different behaviours may depend on something related to the video card..
Post by StompinTom » Tue Feb 07, 2012 9:54 pm
Would it be possible to finally kill the 'material index out of bounds' error? If an object from Blender has a material assigned that is not used for any of its faces, then Indigo won't render it. Frustrating for large, imported scenes.
Also, any updates on the instancing + precision issue?
Otherwise, will test this out once I get a bit of time!
Post by lycium » Tue Feb 07, 2012 11:25 pm
No change on the instancing, since generally we don't see any problem with it; if you could send us a scene showing such precision issues I'll definitely look into it though.
Post by OnoSendai » Sat Feb 11, 2012 3:26 am
Thanks for bug report Pibuz. Fixed for 3.2.8.
Users browsing this forum: No registered users and 124 guests
