Rocking Chair
Rocking Chair
I started this a while ago to improve my basic modeling skills and to get a better handle on UV mapping.
It still has a few issues in the modeling department but it's mostly done, so next I need to UV map it.
I've been trying to find some high quality free textures but have about decided that the time I already spend searching is better spent improving my UV map skills. Where do you get your hightg res, high quality textures (other than from Arroway.de) ?
The design of the chair is not my own but is the signature chair from David Haig:
http://www.davidhaig.co.nz/rocking_chair.html
Re: Rocking Chair
Interesting chair! Only wondering about the weight it could handle...
Well for the texture I think you know cgtextures.com ? But there is another one which could be a better choice for your chair http://www.2textured.com there are quite a lot high res wood textures.
Rocking Chair
David Haig has built several hundred of these over the years for clients worldwide so I'd believe that the load bearing capacity is not an issue.
I have a subscription
to the Fine Woodworking magazine and this chair and his work was featured in the Pro Portfolio section.
Having had this subscription for a number of years a while ago I decided to just model some of the designs I liked. There are a number of furniture makers that make stunning stuff that would truly enhance many fine renders that currently feature another piece of furniture. The Eames chairs are nice but there is better stuff out there.
I did not find what I was looking for on cgtextures but will check out the other site you mentioned. Thanks!
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Re: Rocking Chair
Making progress, slowly but surely, but slowly.......
UV mapping turned out quite a bit more complicated than I hoped. I think that in the end I'll have spent more time UV mapping it than modeling.
- zeitmeister
Re: Rocking Chair
Great mapping, fantastic!
Keep on! This is what quality visualisation of "simple" objects defines!
haluperido
Re: Rocking Chair
Really nicely done - looks real!
tar_gniK
- 3D Software: 3ds Max
Re: Rocking Chair
I love renders like this. I second what Zeitmeister said.
Question: Can you elaborate on how you fitted the mapping so that it curves? Particularly, looking at the leg.
Re: Rocking Chair
hey Max,
your bump map looks quite... questionable
if you use a "grey centered" bump map try to set indigo to use it also that way!
simply set your "b" at a value and "c" at 1/2 of "b" negative, example:
b:0.05 c:-0.025
By that you don't only get bump inside your model, but also some to the outside and end up with a less artificial bump behavior! Also use a map based of high contrast bump map for exponent map, so your scratched holes in the wood don't shine so nicely, since the aren't in the real world too
b:0.05 c:-0.025
Re: Rocking Chair
Beautiful texturing. Keep going!
Re: Rocking Chair
Thanks for the kind and encouraging remarks!
Here is another full view of the chair, now fully UV-mapped. As I had anticipated, the arm rests were quite a challenge and in the end required compromises so I have to be careful from what angle I do my "shots"
@ Zom-B
Thanks for the helpful hints! The initial material was a simple blend between a diffuse and phong with a bump maThe material is a blend between a diffuse and phong blended by the "exponent" map. The textures are from the Arroway wood collection and come with a "specularity" map, which I had to adjust the level on to get any effect in Indigo. I've tried in previous projects to use it "straight" as a exponent map but were unsuccessful. The blend technique is what I've had the most success with so far.
@ tar_gniK
I use Blender however I'd assume this is not much different from most higher end 3D packages. For mor complex shape and the best control you first define the seams where you want your mesh to be "cut open". then you click on Unwrap and Blender unwraps the mesh for you while trying to observe as small a of a mesh deformation as possible. How small depends on the complexity of the mesh and your skill in defining the seams. Blende offers a good number of editing methods for UV-maps. You can use proportional editing to gently pull the UV-map into shape to get the desired mapping effect.
I am still tuning the lighting and the material. Any good suggestions as to how to avoid the ugly color banding ?
@ Zom-B
@ tar_gniK
Re: Rocking Chair
If you mean the banding in the background, I don't think it's such a terrible thing, as it gives the suggestion of a background/form as opposed to a flat surface or gradient. Having shadows come into the scene from objects/lighting outside the shot can suggest a bit of context.
Anyway, texturing looks great. I would just smooth out your background object and angle your lights a bit better.
Re: Rocking Chair
You could move your light sources around a little or add something to break up the backdrop, subtle bump/texture - noise really.
Re: Rocking Chair
Smoothed out lighting a little bit and added some texture to the background. Back to fine-tune the material for the close-up shot.
- LithiumDesign
Re: Rocking Chair
Great work with the modelling and texturing!! The backdrop material seems like it's repeating too often, maybe try and just make a noisy/patchy tecture, very subtle and no bump? Maybe a map like this, lower the contrast of the map to make it less "harsh"Headroom wrote:Smoothed out lighting a little bit and added some texture to the background. Back to fine-tune the material for the close-up shot.
I used the attached map on my table -
Users browsing this forum: Majestic-12 [Bot] and 130 guests
