Another SSS Test
What about bump map an SSS? It seems to be somewhat supported, but the uv coordinates are rendered wrong.
Suvakas
Suvakas
OnoSendai wrote:not right now...suvakas wrote:Can we use texture map with SSS material?domparis wrote:Cool head !!
Do u plan to texture it ?
Cheers
Dom
Suvakas
But it would be useful...
I just have to work out how to do it, probably some kind of local modulation of the absorption coefficients (similar to what Jensen does)
playmesumch00ns
thank you very much for all your help, this is just great.
i am trying to cope with that shader. mainly my idea was the following:
1. try to get the depth and color right (in progress)
2. get the surface working (when no 1 is ok)
no 1 is just possible if i can see clean results, and that´s the point about those renderings. i learned alot about that shader by trying around with an ior of 1.
i will try around with the other params now and post my results
new test, this time a lightning test, to show the colors somehow better.
sorry, didn´t have much time, so i had to stop rendering after short time.
i think i am getting closer.
there is a question though:
when i activate glossy reflection and set ior to 1.4, the material tends to get very dark (even with bright surroundings) why is that? and is there a possibility to control the opacity of the speculars?
