Another SSS Test
tungee
super
Post by tungee » Wed Feb 14, 2007 11:56 pm
this is the right way man!
very good.
Post by suvakas » Thu Feb 15, 2007 12:52 am
What about bump map an SSS? It seems to be somewhat supported, but the uv coordinates are rendered wrong.
Suvakas
OnoSendai wrote:
suvakas wrote:
domparis wrote:Cool head !!
Do u plan to texture it ?
Cheers
Dom
Can we use texture map with SSS material?
Suvakas
not right now...
But it would be useful...
I just have to work out how to do it, probably some kind of local modulation of the absorption coefficients (similar to what Jensen does)
Post by OnoSendai » Thu Feb 15, 2007 12:57 am
bump mapping is applied to the material, which is independent of the internal medium. Whether the medium has SSS or not shouldn't affect the UV coords.
Isigrim
Post by Isigrim » Thu Feb 15, 2007 1:44 am
i rendered a new image, mainly to see the shader in detail.
now the absorption is somewhat higher.
(click to see "highres"-version)
now the ear problem is visible a lot better.
Post by OnoSendai » Thu Feb 15, 2007 1:51 am
The problem with the ear is that the scattering coefficients are not high enough, so light can pass straight thru without changing direction.
So increase the scattering coefficients.
Unfortunately this slows down the convergence speed :P
manitwo
Post by manitwo » Thu Feb 15, 2007 2:00 am
another stunning result isigrim!
i wonder if the ior value of "1" is right?
if someone knows, whats the ior of skin?
Post by OnoSendai » Thu Feb 15, 2007 2:14 am
manitwo wrote:another stunning result isigrim!
Roughly 1.4.
playmesumch00ns
Post by playmesumch00ns » Thu Feb 15, 2007 2:14 am
About 1.4 i think. Greasy water basically ;)
Post by OnoSendai » Thu Feb 15, 2007 2:15 am
playmesumch00ns wrote:About 1.4 i think. Greasy water basically ;)
lol :)
manitwo
Post by manitwo » Thu Feb 15, 2007 2:19 am
Roughly 1.4.
thanks :P
Isigrim
Post by Isigrim » Thu Feb 15, 2007 2:28 am
thank you very much for all your help, this is just great.
i am trying to cope with that shader. mainly my idea was the following:
1. try to get the depth and color right (in progress)
2. get the surface working (when no 1 is ok)
no 1 is just possible if i can see clean results, and that´s the point about those renderings. i learned alot about that shader by trying around with an ior of 1.
i will try around with the other params now and post my results
Isigrim
Post by Isigrim » Thu Feb 15, 2007 7:09 am
testing a two layer setup. cut out a small part of the face and used it as "testlayer".
will show a better render and the .xml tomorrow
Isigrim
Post by Isigrim » Fri Feb 16, 2007 7:41 am
new test, this time a lightning test, to show the colors somehow better.
sorry, didn´t have much time, so i had to stop rendering after short time.
i think i am getting closer.
there is a question though:
when i activate glossy reflection and set ior to 1.4, the material tends to get very dark (even with bright surroundings) why is that? and is there a possibility to control the opacity of the speculars?
manitwo
Post by manitwo » Fri Feb 16, 2007 8:08 am
Isigrim wrote:when i activate glossy reflection and set ior to 1.4, the material tends to get very dark (even with bright surroundings) why is that?
same problem here. :P
Users browsing this forum: No registered users and 131 guests
