ninopiamonte
Post by ninopiamonte » Thu Jan 19, 2012 11:30 pm
it's RAON, in gunbound.....
haluperido
Post by haluperido » Fri Jan 20, 2012 8:06 am
vis4arch wrote:@haluperido
very nice rendering!
would you share some info about the modeling process, and setup.
Thanks
Hi, glad you like it :) This is quite simple scene lit by exr image from http://www.openfootage.net
Pebbles were made using patch objects and blender particle system, grass as well. All of this weight painted on the displaced plane. Water is a cube with subdivided and displaced top face. Rest is plain indigo magic ;) All done in about 35minutes.
Antonis777
Post by Antonis777 » Sat Jan 21, 2012 10:37 am
My first exterior try... A traditional greek house. Need your comments and some advice...!
dcm
Post by dcm » Sat Jan 21, 2012 10:43 am
Antonis777 wrote:My first exterior try... A traditional greek house. Need your comments and some advice...!
shaders,shaders,shaders,postpro
Antonis777
Post by Antonis777 » Sat Jan 21, 2012 11:14 am
Could you give me an example of how and where could I use shaders ?
Post by CTZn » Sat Jan 21, 2012 12:25 pm
Probably he meant more work on materials in general, and insistently. For instance you could map Phong's exponents, don't forget then to scale the texture b parameter by the maximum exponent targeted.
For instance with a black to white texture, if you want black to represent a minimal exponent of 322 and white to represent a maximum of 4356, you set:
Offset (c) to 322
Scale (b) to 4356 - 322 = 4034
That's an arbitrary eample. Funny how many times I had to edit that line, time to... yawn.
In terms of post-pro the Camera tonemapping would be a great start. It's a nice scene I think.
To all, how about posting actual WIPs into the forum ? This thread is going to explode and we want to know more !
Post by Headroom » Sat Jan 21, 2012 1:28 pm
Theoretically posting it in a WIP thread is a good Idea. In reality I believe that unfortunately you get the most responses when posting it in this thread rather than in a separate WIP thread.
Once you subscribe to this thread you get a notification email if a new post is made and I think that's the trigger for many to drop by. When a new separate thread is made (WIP or else) that is not necessarily the case.
Post by CTZn » Sat Jan 21, 2012 2:08 pm
I can see your point Headroom, I'm standing otherwhere, by default of course.
I wanted to say that user's work would have a more specific attention into a dedicated thread. If I may interpret your say, what is expected from this topic are images not explanations. In this regard I am also often the first in cause so I'll withdraw myself ;)
I meant to help, and helping one helps many in turn. Anyone willing to explore existing options in more depth can contribute by dropping a link to a wip along with the images.
ninopiamonte
Post by ninopiamonte » Sat Jan 21, 2012 5:25 pm
:D
better add bump and shine on the floor
Post by CTZn » Sun Jan 22, 2012 9:10 am
scrap from random tests over a recent period.
sphere primitives with an air medium hollowing glass.
testing glass acceleration under various situations
Maya 2012 Substance test
Someone !?
ninopiamonte
Post by ninopiamonte » Sun Jan 22, 2012 6:44 pm
some background tests with a bird.,.......
and some wheel problems...(no rubber material)
ENSLAVER
Post by ENSLAVER » Sun Jan 22, 2012 11:01 pm
Went back to an old version of max to play with rayfire
ninopiamonte
Post by ninopiamonte » Mon Jan 23, 2012 1:04 am
how did you do with that blur (falling action) at
the first image??
Xaon
Post by Xaon » Mon Jan 23, 2012 4:33 am
J'aime bien modéliser des meubles (n'étant pas très doué en architecture).
Je vous présente ma table à manger "Basico"
ninopiamonte
Post by ninopiamonte » Mon Jan 23, 2012 12:04 pm
is this what you mean?
I like modeling of furniture (not very good at architecture).
This is my dining table "Basico"
