LithiumDesign
by LithiumDesign » Wed Jan 11, 2012 8:25 am
Just a warm up exercise, an oak cabinet/coffee table
think I made the texture's a tad big - makes the table look smaller than it actually is?
LithiumDesign
by Headroom » Wed Jan 11, 2012 1:02 pm
As you mentioned the wood grain should be smaller/finer in scale. Also the way this is mapped is not how that sort of conventional furniture is typically built. The grain on the vertical Boards should run vertically.
LithiumDesign
by LithiumDesign » Wed Jan 11, 2012 10:39 pm
Headroom wrote:As you mentioned the wood grain should be smaller/finer in scale. Also the way this is mapped is not how that sort of conventional furniture is typically built. The grain on the vertical Boards should run vertically.
Thanks for the advice! I see what you mean, I was lazy and just used the UVW map modifier! I really need to learn how to map a texture in 3ds!
by StompinTom » Wed Jan 11, 2012 11:51 pm
Maybe it's just veneer glued over MDF
FoXar
by FoXar » Thu Jan 12, 2012 1:35 am
Nice work Lithium, I really like the wood texture! But as mentioned before it looks tad too big.
Reminds me of something I'm working on..
(Don't look at the terrible scene setup..
Cheers!
Roo Evans
LithiumDesign
by LithiumDesign » Thu Jan 12, 2012 1:57 am
StompinTom wrote:Maybe it's just veneer glued over MDF
how did you know?!
FoXar wrote:Nice work Lithium, I really like the wood texture! But as mentioned before it looks tad too big.
Cheers!
Roo Evans
Thanks FoXar! Yours is very sleek, is there a wood texture on the outside or a dark plastic? I can't tell sorry!
Also I see a dark line through the drawers, might just be my screen? Keep it up!
EDIT: Properly textured the coffee table, added some ornament things and rendered it at a fancy camera angle and res
haluperido
by haluperido » Sat Jan 14, 2012 5:37 pm
finally got some more time to play with indigo
little pebbles test for a bigger scene
Stinkie
by Stinkie » Sat Jan 14, 2012 9:50 pm
That looks great.
by zeitmeister » Sat Jan 14, 2012 11:45 pm
@lithium:
The furniture and the wood material looks great!
by zeitmeister » Sat Jan 14, 2012 11:47 pm
@haluperido:
Great colors! Does that blue water come from your water material?
haluperido
by haluperido » Sun Jan 15, 2012 7:33 am
Hi Zeitmeister! This great water material is from database (Rippled Water by OnoSendai) I've only changed wave height to 0.001.
cotty
by cotty » Sun Jan 15, 2012 9:46 am
Playing around with some scrabble stones...
dcm
by dcm » Sun Jan 15, 2012 10:01 am
cotty wrote:Playing around with some scrabble stones...
inri
vis4arch
by vis4arch » Thu Jan 19, 2012 1:10 am
@haluperido
very nice rendering!
would you share some info about the modeling process, and setup.
Thanks
all the best,
tamas
berg8 -
werbeagentur
. design . web . marketing .
Users browsing this forum: No registered users and 78 guests
