exit portals are not doing well with single path tracing and sun, though one of the two PT mode may work better than the other (w/o GPU). Bidir and MLT should use them fine.zeitmeister wrote:Since when are exit portals working with anything exept sunsky? Did I miss something?
First Interior - Lithium Design
Re: First Interior - Lithium Design
Just to iron that out:CTZn wrote:...though one of the two PT mode may work better than the other
the restriction here is only for pure PT (as used in GPU mode too)!
BiDir PT works fine, same as MLT and BiDir MLT.
