My material testing scene
Hello world
I decied to share my test scene for material creation inside of indigo. Scene was made by Piotr Dacewicz and me. Scene is calibrated to give most neutral result.
Model is placed inside of the box which have dimensions 1x1x1m . Inside are 2 emitters placed in 2 layers, so you guys can simply switch between them to check material in some more ways.
Every side of the box is mapped with texture with neutral color. Textures works like indicators (see image below).
Of course, scene is not perfect so please, if u find some bugs, feel free to report.
using agfapan100cd with EV 7,5 and ISO 200 you can get similiar result like with linear output but agfapan produce lil bit more contrast and less highlights. Really nice output
You can zoom to object easily to check, if your material is good. With realtime editing, this scene is powerful tool for material creation.
This scene will be probably implemented inside of new IndigoMax as basic mat. preview scene.
PS : for rendering of dielectric materials (glass, water etc.) i recommend to use supersamples factor 3/4 to avoid fireflies or use MLT. For faster rendering, use smaller resolution.
I wish you a lot of fun with that. Some images (scene to download at bottom):
- zeitmeister
Re: My material testing scene
Thank you very much, guys...
this is very helpful! Great idea with the light layers to test bump and specular.
And wonderful neutral light!
im glad its helpful. feel free to post some tests if u do
..you mean that this scene is IN METERS?
HOLY GOD, I've been asking for this for ages
Gonna test this, guys! Thanks a lot!
..unfortunately I can't make it to work as a SkIndigo preview scene
maybe someone can tweak ?Pibuz wrote:..unfortunately I can't make it to work as a SkIndigo preview scene
YEP, I hope someone more EXPERT will help usdcm wrote:maybe someone can tweak ?Pibuz wrote:..unfortunately I can't make it to work as a SkIndigo preview scene
Thanks for your great work btw, Piotr and Dcm!
can you explain, which problem do u have ? you can still open this scene inside of indigo, create material and save and import to skindigo
One note :
using agfapan100cd with EV 7,5 and ISO 200 you can get similiar result like with linear output but agfapan produce lil bit more contrast and less highlights. Really nice output. Im also using agfapan100cd in every scene as default camera
I just wanted to integrate your scene inside our mat preview of skindigo. Seems like it's a quite hard task!dcm wrote:can you explain, which problem do u have ? you can still open this scene inside of indigo, create material and save and import to skindigo
But don't worry, I'll just wait for some hints by Snorky
im posting 2 new testscenes. Both are from mrmaterials.com. I just tweaked them for usage inside of indigo. There are 2 zip files with PIGS inside.
One is for dielectric (water,glass), sss and all transparent materials. Why ? Scene is without mapping coordinates.
Second files is for mapped materials, scene contains UVW coordinates. Files and examples below.
HDRi used as light source is from hdrlabs.com
- testscene for mapped materials with UVW coordinates.zip
- (5.25 MiB) Downloaded 655 times
- testscene for dielectric and sss materials without UVW coordinates.zip
- (6.53 MiB) Downloaded 645 times
