when i clicked the button Talk to Indigo from shelf, i got this error from Indigo
Error: Scene parsing error: Found unexpected element 'model'. (In element 'skylight', around line 35, column 1)
please help me i am new to Indigo
Exporting
Re: Exporting
exporter version?
indigo version?
indigo version?
Re: Exporting
Hi Abu Backer,
The Indigo version that you are currently using does not feature the new captured sky simulation.
Likewise, the Mixed environment type will not work with, ie, Indigo 2.6.1. At this point you have two options:
- Activate the "original model" checkbox for 'Sun' into the Indigo Editor for Maya (called by the first shelf button). I almost forgot, the third shelf button (a disc into the Indigo logo shape) is a shortcut to the current directional light used as sun.
or
- Install Indigo 3.2. http://www.indigorenderer.com/forum/vie ... =1&t=11260 and use the new sky model.
It is a good practice to match Indigo versions with exporters versions, and test the newest versions of each together. As snorky suggested, it is also a good practice to report exporter, Indigo and 3d application versions along with errors/bugs reports.
The Indigo version will be detected at some point by MtI to avoid such errors. Thank you for the report.
or
Re: Exporting
A similar error that you may experience right after with 2.6.1 is "Found unexpected element 'sharp'."
Click the second shelf button, go to the 'Image' tab and change 'sharp' to another oversampling filter. If you haven't installed Indigo 3.2 already.
Abu Backer
Exporting
You need to upgrade to Indigo 3.2.2.
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Re: Exporting
It is necessary at this stage to upgrade Indigo 3.2.2. It is tough for me, So much short time to do.. Because I should complete the task within very short time limit..
