mrmoose
by mrmoose » Wed Feb 14, 2007 4:18 am
Thank's Nik!!!
A simple question. What is the right sintax for resume option (with 2 thread):
1) indigo xyz.xml -t 2 -r renders/igifile.igi or
2) indigo -r renders/igifile.igi
Does the .igi file contains the source data and command parameter too?
mrmoose
mrmoose on Wed Feb 14, 2007 4:33 am, edited 1 time in total.
Kojack
by Kojack » Wed Feb 14, 2007 4:30 am
OMG resume option? I must try it now!!!
Camox
by Camox » Wed Feb 14, 2007 4:47 am
suvakas wrote:This clip should be from a Finland TV show where they teach how to disco dance. I have the show somewhere on my harddrive. It's from late 70's or something like that.. Pretty funny
[edit]
Yep, same show
Suvakas
VictorJapi wrote:drBouvierLeduc wrote:resume fonction + tonemapping gui : splendid.
-->Camox : I had to say something about your avatar... it's... you know... rockn'roll (not sure what I wanted to say, but I said it)
C'mon and dance with Disco Utah baby!!!
LOL
, you know a lot. I like the avar, looks pretty funny. Lets rock...
tungee
by tungee » Wed Feb 14, 2007 5:05 am
what does resume do?
afecelis
by afecelis » Wed Feb 14, 2007 5:36 am
it allows you to render a scene for a certain amount of time, stop it and then retake it later from the point where you left it. Or you can even start your scene on your pc, stop it, take the files to your friend's megamonster super duper pc, render the scene there and so on
tungee
by tungee » Wed Feb 14, 2007 6:03 am
how big is the .igi file 500MB?
tungee
by tungee » Wed Feb 14, 2007 6:04 am
has maxwell has this or fryrender?
Kosmokrator
by Kosmokrator » Wed Feb 14, 2007 6:11 am
maxwell have this feature....
the igi file is big...about 150mb it depends from resolution...(i think)
manitwo
by manitwo » Wed Feb 14, 2007 6:16 am
hmm ... my .igi files are around 5,5mb (800x600).
Kosmokrator wrote:maxwell have this feature....
afaik they
had this feature.
Kosmokrator
by Kosmokrator » Wed Feb 14, 2007 8:53 am
manitwo wrote:hmm ... my .igi files are around 5,5mb (800x600).
afaik they
had this feature.
hehehe manitwo if Ono Make some atmosphere on their physical sky system (clouds..fog,haze..)Indigo it will be 1st in the World have all this features...
LaurentA
by LaurentA » Wed Feb 14, 2007 9:19 am
Thanks for the resume function, but I have a problem:
When I render "phong_test2.xml", stop and resume, indigo restart with "phong_test.xml"!!!
I just tried with "dof_test.xml", and it goes the same!
(with this example, "phong_test.xml" being way darker that "dof_test.xml", it do not show as much as on "phong_test2.xml", but even the window's title says it is rendering "phong_test.xml"!
manitwo
by manitwo » Wed Feb 14, 2007 9:32 am
don't know if this helps but check your inifile.txt: the "scenefilepath" should
point to your scene which will be resumed.
raducoc
by raducoc » Wed Feb 14, 2007 10:11 am
The "tonemapping_test.xml" provided with 0.7t5 version of Indigo dont work! Firstly I getted a lot of errors regarding materials. I deleted this sections and replaced with materials from other files but now Im getting the following error message: "SceneLoaderExcep: TinyXmlWrapper: could not find element "normal_smoothing" in element "mesh" (around line 100)". But in the entire file isnt any "normal_smoothing" word, so, I cant manage to fit the file! Any help?
manitwo
by manitwo » Wed Feb 14, 2007 10:24 am
raducoc wrote:The "tonemapping_test.xml" provided with 0.7t5 version of Indigo dont work! Firstly I getted a lot of errors regarding materials. I deleted this sections and replaced with materials from other files but now Im getting the following error message: "SceneLoaderExcep: TinyXmlWrapper: could not find element "normal_smoothing" in element "mesh" (around line 100)". But in the entire file isnt any "normal_smoothing" word, so, I cant manage to fit the file! Any help?
All of the <mesh> tags should have a child <normal_smoothing> tag, like that:
<mesh>
<name>meshName</name>
<normal_smoothing>false</normal_smoothing>
<external>
<path>meshFile.3ds</path>
</external>
</mesh>
domparis
by domparis » Wed Feb 14, 2007 3:25 pm
Wow, thanks Nick, 2 new test version and 1 new tool, i can notice some speedup, and the resume/igi feature kick ass, obj support is fixed and cache tree is back !!!
Cheers
Dom
