Indigo Renderer 3.2.0
- zeitmeister
Re: Indigo Renderer 3.2.0
Step blend is working here for me; only getting darker areas when using any bidirectional rendermode.
Would be nice if this could be fixed, too...
Maybe as a quick workaround for this: Try loading a texture with alpha channel into the albedo, that should work nowadays too.StompinTom wrote:Alpha materials seem to be busted... My leaf materials don't seem to take into account any blend maps or such...
We fixed the issue on 10.7 and uploaded a new Mac build.
1) a gui bug: where is "render settings tab"!?!??!
2) another gui "bug": zoom level % inverted
That's unusual, can this be fixed through the Window menu ? You could try to reform a layout...snorky wrote:1) a gui bug: where is "render settings tab"!?!??!
Is this permanent or ponctual for you Snorky ?
Happens every time you open the programCTZn wrote:That's unusual, can this be fixed through the Window menu ? You could try to reform a layout...snorky wrote:1) a gui bug: where is "render settings tab"!?!??!
The render settings tab is always hidden behind another tab
Moving the "up tab" it appears and then remains visible (until the next time you open the program...)
(sorry... google translation)
- zeitmeister
@Zom-B:
transparent images?!?
PNGs with alpha? Since when does Indigo recognize them?!?
Really missed that!
Really missed that!
I'm getting a permissions denial when trying to download the Mac version. All others work fine. Is it available now?
@snorky: close all indigo instances but one, reset layout from the menu, rearrange layout and restart Indigo. That should do.
no...CTZn wrote:@snorky: close all indigo instances but one, reset layout from the menu, rearrange layout and restart Indigo. That should do.
Rendering settings tab is hidden behind other tab (it appears only if is alone on column/row layout)
now tested on new notebook (clear installation), same problem. (and same problem with zoom %...)
Sorry about that, should be fixed now.sidewalk wrote:I'm getting a permissions denial when trying to download the Mac version. All others work fine. Is it available now?
Thanks so much for a speedy fix! Rendering away!
CUDA reporting out of memory now.. will investigate more.
Jeff Hammond
fused wrote:We fixed the issue on 10.7 and uploaded a new Mac build.
working now.
thank you!
I have problems with the license key of my slave.
Verification of the license key fails with 3.2.0. changed back to 3.0.14 and it works!
Win 7 64 bit
Win 7 64 bit
Hi guys!
Wonderful mood change between the old sky and the new one! VEEEERY GOOD!
..but I must report that the new sky is limited to a half-sphere. The old sky model (in skindigo it's called "legacy sky") worked well, and still does if enabled.
See attachments. Thanks!!!
