SkIndigo 3.2.2 (beta)
Many fixes in this release and a few new features. Please consider this a test release. Requires Indigo 3.2.0.
#Version 3.2.2
#Fixed: mesh errors due to float export bug introduced in version 3.2.0
#Version 3.2.1
#Fixed: emission scale bugs
#Fixed: 'No such Material Default' errors
#Version 3.2.0
#Added: support for new Indigo sky model (to use old model, enable the legacy sky model checkbox in Render Settings)
#Fixed: Texture editor thumbnail not changing when loading new texture in certain situations
#Changed: completely reworked workflow for using multiple UV sets (UV sets created, saved, and loaded using Mesh Editor)
#Changed: throws error message and aborts rendering if not using perspective camera
#Added: support for SketchUp Image components (exported as diffuse material - cannot be edited inside SkIndigo)
#Fixed: normal smoothing precision errors introduced in version 3.0.15
#Removed: UV Mapping context menu
#Removed: 'Position Map' button in Texture Editor
#Added: UV Mapping options in Object Editor
#Changed: Object Editor now displays properties of the active mesh (group/component) not the selected one
#Added: automatic Indigo version compatibility check at SketchUp launch
#Changed: resolution preset from 1280x1024 to 1280x720
#Added: World scale setting (in advanced parameters)
#Changed: '..' button shows red background if invalid file reference is found
#Changed: emission scale of environment map now controlled by the emission scale setting of the env map material, not the render settings slider
#Changed: made it optional to export object animation
#Fixed: multiple UV sets
#Changed: no longer loading meshes from cache due to SketchUp not refreshing GUIDs when changing UVs of a mesh
#Fixed: error when applying an environment map material to normal geometry
Please report any bugs and error messages found in the Ruby Console Window.
EDIT: Updated to version 3.2.1 with two critical fixes
EDIT: Updated to version 3.2.2 with critical bug fix
Thanks for testing!
Enjoy!
SkIndigo 3.2.2 Windows Installer
Mac build coming soon...
#Version 3.2.2
#Version 3.2.1
#Version 3.2.0
Thanks for testing!
Enjoy!
Re: SkIndigo 3.2.0 (beta)
This is great. Thanks Whaat! We'll let you know of the bugs, if we spot any
indigo 3.2
skindigo 3.2
OS 10.7.2
indigo crashes.. skinidigo appears to export the scene.. indigo tries to launch then crashes every time.
not sure if this is a skindigo or indigo problem?
help !
skindigo 3.2
OS 10.7.2
help !
Hi Jeff,Jeff Hammond wrote:indigo 3.2
skindigo 3.2
OS 10.7.2
help !
Did this scene work before with previous Indigo/skindigo versions? Can you try reverting to SkIndigo 3.0.15 or 3.0.14 to see if it works? (Both of these will work with Indigo 3.2.0)
Also, could you post the PIGS file for testing? Thanks!
hey Dale,Whaat wrote: Did this scene work before with previous Indigo/skindigo versions? Can you try reverting to SkIndigo 3.0.15 or 3.0.14 to see if it works? (Both of these will work with Indigo 3.2.0)
it was just a clay cube which i tried testing but i'm not exactly sure where thing went wrong.. i sent the .pigs to support earlier and yves said he's isolated the issue so i'm assuming it's something in indigo itself.
i haven't tried this on my desktop (which has earlier working versions of skindigo/indigo).. i'm on my laptop which is use to test the betas so i'm not sure if the file works with older versions or not..
here's the pigs if you want to have a poke around though..
- crash.pigs
- (2.79 KiB) Downloaded 292 times
Same as Jeff:
Indigo 3.2
skindigo 3.2
Mac OS 10.7.2
Indigo can render only the caterpillar scene,
If I try to export from shindig, Indigo launches and crashes every time.
Thanks!!
Indigo 3.2
skindigo 3.2
Mac OS 10.7.2
Thanks!!
lol.. that kept happening to me.alffrad wrote: shindig
if you right-click on the word skindigo when it's underlined in red then choose 'Learn Spelling', Lion will quit trying to auto-correct 'skindigo'..
Re: SkIndigo 3.2.1 (beta)
I don't know, I'm liking Shindig.
Is it too late for a name change?
- kwistenbiebel
Hi Whaat,
The issue mentioned here: http://www.indigorenderer.com/forum/vie ... 17&t=11184
remains unresolved in the new Skindigo/Indigo
There is a scale bug when applying the "scale" new feature
See http://www.indigorenderer.com/forum/vie ... 1&start=15
I have selected tracing mode "alpha render" in the skindigo section advanced parameters, it didn't render an alpha image, because of the checked GPU acceleration checkbox. It would be heplful if a messagebox hints towards this problem or the checkbox is deactivated automatically with alpha render active.
Cotty
Cotty
Hi Whaat!
The red signal indicating the missing textures is a wonderful addition!! Thanks a lot!
Yet, I encountered a little issue with that, I'm trying to reproduce it but I am in a little hurry so I think I will in the next days.
I was also trying the new workflow of the mesh editing: are the parameters supposed to work with all geometries (free faces) or only with groups/components?
BTW, I saw that selecting different geometries leaving the window open doesn't update the mesh info in the window (it would be cool to have the automatic update, sort of "entity info" panel of SketchUp).
Moreover, the mesh info seems quite wrong: the "active mesh" counts the free faces in the model, ignoring the selection. Is that correct? I can be totally wrong, since this is a new SketchUp feature.
I also report that the world scale function is a little buggy (reported in the Indigo main engine topic): the three axes aren't scaled uniformly, but randomly.
Hi Pibuz,Pibuz wrote:Hi Whaat!
In version 3.2.1, the mesh editor reports the properties of the 'active mesh', not the selected mesh (group/component). You need to double-click and enter group edit mode in order to start editing the properties of a particular group/component. This was changed from 3.2.0 for a variety of reasons. I hope it is not too confusing.
Yes, I did see this report. When I tested your file, I found that at 0.01 scale, the issue you reported occurred but at 0.02 scale or greater there was no problem.Pibuz wrote:I also report that the world scale function is a little buggy (reported in the Indigo main engine topic): the three axes aren't scaled uniformly, but randomly.
It is not clear to me yet if this is an Indigo bug or a SkIndigo one. I need to investigate further.
Thanks for the report!
Please continue to test this feature at other scale levels to see if you find any other problems.
