Cuda Help with 2 cards
Come here for help & support.
8 posts • Page 1 of 1
kdarius
Post by kdarius » Fri Nov 04, 2011 5:27 am
Hey team,
I came across this issue and was hoping you could help. I have recently had a need to add a 3rd monitor. So i took apart an older computer and used its Nvida Quadro FX 1700 in my new computer. My new computer already had a Quadro 5000. Now it seems when i open up Indigo Render with the two cards in my computer Under GPU Acceleration it lists both cards but they have OpenCl beside them. Why is CUDA gone? I dont even care is indigo uses the FX 1700 but i want it to use cuda for the 5000.
Thank you,
Darius Kirschner
Re: Cuda Help with 2 cards
Post by lycium » Fri Nov 04, 2011 6:17 am
Are you drivers up to date? This is the most important thing for GPU accel, esp after installing new hardware.
kdarius
Post by kdarius » Fri Nov 04, 2011 6:30 am
I have told windows to search for updated drivers and they it says its up todate. Do you have any idea what driver number i should be using?
Post by lycium » Fri Nov 04, 2011 6:47 am
Better get them yourself, I'm not sure how often Windows Update does or if it even updates them at all.
http://www.nvidia.com/Download/index.aspx?lang=en-us
285.05.09 Certified is the latest version atmo.
kdarius
Post by kdarius » Fri Nov 04, 2011 7:21 am
Awsome totally worked. So dont relly on windows finding the most up to data drivers now i have cuda and openCL for both cards
Post by lycium » Fri Nov 04, 2011 7:29 am
Fantastic 8)
kdarius
Post by kdarius » Fri Nov 04, 2011 7:32 am
wierd thought when i render the pin test using GPU i get 1050 SPS and if i use my cpu with render mode path tracing if get 2030 sps
Post by lycium » Fri Nov 04, 2011 7:38 am
The samples/s measurements might be different for the GPU mode, because of the non-circular aperture used in that scene.
