I imported material (Clear Natural Water w/ cauchy) with Cindigo3.0.11 and 3.0.15.
(http://www.indigorenderer.com/materials/materials/30)
However, imported content seems to be different ...
C4D R10.5 (64bit)
Indigo 3.0.14, Cindigo 3.0.15
Windows 7Pro(64bit), MEM 8GB
I used machine translation ...
P.S. Should the report about Cindigo reach here?
Import material
- Ryouta Sumeragi
Re: Import material
Hi Ryouta,
thank you for the report. I will look into this issue.
The values are the same(3.25E-002 is 0.0325, etc), but the start an end wavlength are completely off.
When rendering the material with each of the versions, to they end up looking the same? Does one give an error?
Kind regards,
Yves
Kind regards,
Yves
- Ryouta Sumeragi
Re: Import material
In Ver3.0.15, I did not come by rendering...fused wrote: When rendering the material with each of the versions, to they end up looking the same? Does one give an error?
In Ver3.0.11, I seemed to come by rendering definitely.
Re: Import material
Hi Ryouta,
I fixed this issue for the next release.
Regards,
Yves
Regards,
Yves
- Ryouta Sumeragi
Re: Import material
Thanks!fused wrote:Hi Ryouta,
Regards,
Yves
Users browsing this forum: No registered users and 84 guests
