Error: Can't find material "default"
12 posts • Page 1 of 1
Frutiger
Post by Frutiger » Fri Sep 09, 2011 5:58 am
This one's fun:
Error while building scene: No such material 'Default'
Anyone else run into this?
Re: Error: Can't find material "default"
Post by Whaat » Fri Sep 09, 2011 7:21 am
Frutiger wrote:This one's fun:
Are you using an external mesh?
Can you post the SKP for testing?
alffrad
Post by alffrad » Fri Sep 09, 2011 8:08 am
It happened to me too...
I thought I was doing something wrong, so now every time I change materials or add a component from another file, I try to send it to indigo so I know what maybe causing the problem and I can delete it.
also It happened when trying to "purge unused"
alffrad
Post by alffrad » Fri Sep 09, 2011 8:47 am
Hello Whaat,
Please help me before I go insane.. :roll:
In the Skindigo 3.0.15
I can't:
Netwotk Render
Place Enviroment Maps
Instancing
Is this normal? does this works on 3.0.14?
Thanks a lot!
Post by Whaat » Sat Sep 10, 2011 4:26 am
alffrad wrote:Hello Whaat,
I can't:
Netwotk Render
Instancing
Thanks a lot!
Please read the entire first post in the SkIndigo 3.0.15 thread very carefully. :) There were major changes.
Instancing is now handled automatically so don't worry about it.
Environment maps are now handled using Background Materials. Read more in the 3.0.15 thread.
Network rendering works fine for me (no changes were made here). Maybe you were doing something wrong...
I realize that these changes have caused some confusion. I am trying to wrap up some final major changes to SkIndigo 3.0.X and then I plan to create a bunch of tutorials to fully document how to use every feature of SkIndigo 3.0.
Stay tuned... :)
Frutiger
Post by Frutiger » Sat Sep 10, 2011 4:29 am
Just external references in this one. Here's a dropbox link to the file (80 MB). Let me know if there's anything else I can do to help, Whaat.
Alffrad, to be fair, I've been able to get all of those things to work after some fiddling. The new workflows threw me for a loop at first, that's all. Network rendering seems to be the least stable of all, but thankfully the least critical to staying operational. That's probably a questions for the Indigo guys.
alffrad
Post by alffrad » Wed Sep 14, 2011 3:50 pm
I understood Instancing in Skindigo 3.0.15, thanks to Pibus here´s the link:
http://www.indigorenderer.com/forum/vie ... 1&start=15
Then I read "again and again" the Skindigo 3.0.15 thread for the Environment Maps until I realized that I had to create a material and add an "EMITTER" to it. Now I don´t understand how to scale it. But anyways If I render with an environment map, Indigo crashes...
Also I post this for the network rendering:
I CAN´T GET IT TO WORK.
http://www.indigorenderer.com/forum/vie ... =5&t=11068
Thanks a lot!
kwistenbiebel
Post by kwistenbiebel » Mon Oct 03, 2011 4:06 pm
Ruaaaar... I am running into the same error. Error while building scene: No such material 'Default'
Not sure how I can solve this...
kwistenbiebel
Post by kwistenbiebel » Mon Oct 03, 2011 4:21 pm
It's quite urgent that I can solve this :( ...
Post by Whaat » Tue Oct 04, 2011 3:31 am
kwistenbiebel wrote:Ruaaaar... I am running into the same error. Error while building scene: No such material 'Default'
I think this is a bug in version 3.0.15. Can you try rendering with SkIndigo 3.0.14 and see if it works?
kwistenbiebel
Post by kwistenbiebel » Tue Oct 04, 2011 1:09 pm
Hi Whaat,
Thank you for the reply. I hope you have been well :)
I can confirm it does work in Skindigo 3.0.14 together with Indigo 3.0.12.
Post by Whaat » Mon Nov 07, 2011 6:13 pm
This bug should be fixed in 3.2.1 (just released)
Users browsing this forum: No registered users and 150 guests
