Hey Whaat,
Having an issue launching indigo from Skindingo. It may be a Lion issue but I'm not sure so I thought i'd bring it to your attention.
I had indigo crash on me and now this window keeps popping up whenever I try to launch. No matter what I click on it keeps popping up and won't allow me to launch indigo. I have a workaround but it involves holding shift down while separately opening indigo and then exporting the .igs and then opening again which is terribly inconvenient. Here's the window:
Any idea what's up?
Skindigo Indigo Launching Woes
Re: Skindigo Indigo Launching Woes
Hello Frutiger, I had the same problem here with lion too, no matter what I did, restarted etc...
So the only solution i found was to reinstall indigo, Now Its working again...
By the way, can you use network rendering?
Actually, now that you mention it, I can't.alffrad wrote:By the way, can you use network rendering?
But I did try reinstalling Indigo and it's still angry at me. What exactly did you do when you reinstalled?
Uninstall with AppCleaner (just drag indigo Icon) beware! because It will delete all related files with indigo, so check before uninstalling with this app.
And then reinstall Indigo.
I don't remember If I uninstalled shindig too.
( I mean Skindigo )
( I mean Skindigo )
alffrad wrote:Uninstall with AppCleaner (just drag indigo Icon) beware! because It will delete all related files with indigo, so check before uninstalling with this app.
Brilliant! Thanks Alffrad. To be fair to Whaat, this is really a lion bug not a Skindigo one. But the skindingo community always pulls through with a fix!
