Hello all,
I'm fully prepared to be lambasted if this turns out to be a stupid question, but I don't think it is:
I'm trying to get my hands on the material used in all of indigo's material previews. You know the one: white with a grey lines demarcating 10 cm grids. Is this material available for download?
I would love to be able to use this as a filler in tests. Tried looking for it on the material database but no joy. Any help would be met with adulation and nice things being said all around.
Chris
Material Preview Background Grid - a usable material?
Re: Material Preview Background Grid - a usable material?
Hi Chris,
I uploaded the matetial for you to the database (it's just a simple diffuse with a grid texture).
Please keep in mind that, since it is just a texture, the grid will not necessarily correspond to 10cm in your scene, it all depends on how you map the texture.
Here's the link: http://www.indigorenderer.com/materials/materials/1027
Cheers!
Cheers!
I just made a simple procedural grid that requires no UV (but the axis are aligned on world XYZ coordinates)
http://www.indigorenderer.com/materials/materials/1028
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
- PureSpider
It's a 3d texture in world space.Procedural XYZ grid with 1mm, 1cm and 10cm pitch
Nice one Etienne !
- PureSpider
Ooopsie, didn't see thatProcedural XYZ grid with 1mm, 1cm and 10cm pitch
You can use a JPG like the attached as texture (for a 10cm square) to achive the effect.
Cotty
Cotty
Thanks to all
My tests are now looking super super awesome!
